GIAC (confused how to set the GIAC flashloader - rv)
I am confused how to set the GIAC flashloader.
When I connect it to the OBD and press the read button, the read button keep flashing green and doesn't inform what is the current program (stock,pump or race)
If I press the pump button, the pump button flashing light green.
Then I disconnect the Flashloader, turn off ignition, turn on again and connect the flashloader.
I press the read button, the read button keep flashing green.
How should I use the flashloader?
Try sending Mike/A.W.E. a PM. Mike is one of our site sponsors and AWE sells GIAC. Maybe he can answer your Q for you.
Mike@awe-tuning.com
Who did you buy this from?
When you choose a program, the light has to go solid green. That is when you know that you are in the selected program. Flashing green is no good.
Is the key in the on position?
Here is a short video of how it should work.
http://awe-tuning.com/media/multimed...lashloader.wmv
