If I get a C4, what options do I have to improve braking and suspension?
I am strongly considering a C4. But I am also strongly going to miss the braking difference in the S, not the horsepower. Can I improve the braking by upgrading to the same brakes as on the S, or is that not really going to work? Also can the wheels on the C4 be replaced with wheels from the S which I believe are wider?
I am thinking brakes can be improved without affecting warranty, but I don't think the same is true of suspension?
Thoughts? Yeah I could get a C4S but I don't see any CPOs near me, and I am not really willing to take the depreciation on the new car at the moment.
Honestly, unless you plan on doing some serious track days- you will not feel any difference in braking. No need to upgrade.
My guess would be that you could count the cars on the road with better brakes than the standard Porsche brakes using the fingers on one hand. The biggest danger is someone running into you from behind because their brakes are not nearly as good as yours.
The brakes and suspension of these cars are well engineered to match the performance criteria of the respective car(s). Besides, how could you tell whether you are helping or hurting until you put some seat time in? Do not be too quick to think you can do better than Zuffenhausen. Learn the car then you can wisely decide what you want/need to change. My bet is that unless you get VERY involved in DE/Tracking, it wont be much and it will be primarily cosmetic
If you are going to retrofit the brakes and wheels to S components, you might as well get a S to begin with. Front brakes, wheels & tires will run $6K+. The S package also gets Bi-zenon headlamps, PASM & 30 hp for $10K, new, less used. This is not a practical retrofit. Accept a non-S, as is, or keep looking.
One of the first things I noticed when I went to PDE was how good the standard brakes are when you just HAMMER them. We don't even approach the capabilities of the 911's standard brakes when driving on the street. I don't know if you'd shave off any distance with different pads or not but maybe that's an inexpensive option.
But to really get your confidence up on how good the standard brakes are go find a road near your dealership and take your current car up to 80-90 mph and break as hard as you've got the courage to try. Note the distance from top speed to zero. Go take a 997 test drive and go to the same spot, add 10mph to your speed and STOMP on the brakes. I mean really get on them so hard you're thrown into the shoulder belt. You won't swerve, the brakes won't fade and you'll stop a lot faster than in your old car.
And if you do that over and over and over again those brakes are going to hold up and keep stopping you quickly.
Now, I really like PCCB's! But they're pretty expensive and damned hard to heel and toe!
Tony
Tony
Poseur
While all Carrera brakes are outstanding you have mentioned the desire to improve the suspension. If you invest in the PCCB brakes you will absolutely affect the suspension in a very positive way.
Have you driven a 997 for any length of time, not just a test drive. As said by others there are few cars that can match the braking ability of even the standard brakes.
Find someone near you who will let you drive their car for a bit if you haven't already done so and I think you will be impressed.
Check the forum, Steven_H is selling his lightly used C4S
I have a C4 and can tell you first hand that the 'standard' brakes are amazing. It's funny how the "S" badge has somehow diminished the performance expectations of the standard car. Here's mine...
