Garage Floor - Race Deck Installed
I have finished installing Race Deck on the floor of our 2+2 garage. While not particularly difficult to DIY, it is a bunch of work. Each tile connects to its fellow tiles in eight separate places. Every single connection needs a "persuasion tap" with a rubber mallet. Since there are 522 12" x 12" tiles in my 18' x 29' garage, that's a whole lotta tappin' goin' on. Whew.
But it looks nice, doesn't it?
are they slippery? do they provide any "cushion" at all?
Tile prices ranged from $5 each to $3.50 each. They are made of high-impact plastic. They don't seem to be slippery when wet. There is some "cushion effect," but not like carpeting. Hard to explain. The tiles are fairly rigid, but do flex slightly under the weight of a car. The floor is not attached in any way to the cement beneath...it's just "floating" on top - thus it's not "permanent." It can be taken up, broken apart, reconfigured and/or reused.
Originally Posted by gota911
Very nice job! It looks goos. Are you saving that "open slot" on the right side of the garage for a CGT?
One thing I wondered about the Race Deck is how you wash the floor - doesn't the water just run down into the grooves and sit? How do you avoid mold & mildew?
They don't recommend "hosing down" the race deck floor. While the tiles wouldn't mildew or rot (it's reinforced plastic), water that got underneath them would probably evaporate very slowly (depending on conditions).
The floor is not glued down or attached. It's just "sitting on" the concrete.
I wouldn't wash a car on it. Water in large quantities would definitely get underneath.
Needs a Chuckle
I'm envious. Your garage looks great!!! Two neighbors used epoxy on their floors and one used the race deck. I'm going to wait until spring and see how each is holding up before I decide which approach to use.
WOW Now That's nice!!
If by chance water does get under it, you may want to grab a dehimidifier to see if that will assist in removing any that sits under it.
A friend of mine did his floor, same type, but added a plastic barrier between garage cement and flooring. Soon he may go with the Premier garage coating.
You floor looks much better though!! Nice looking with the border!!
Enjoy it!!
Regards,
Deanski
Enjoy it!!
Regards,
Deanski
i had the same tiles down for about 10 months. the one thing i hated was the plastic sounds it made when i walked on them. since then i put down some pergo underlayment. basically its like thin carpet padding. since then its been much much better.
Originally Posted by clif
and how much was it? im having a house built and am thinking of doing this. btw i have a box s and a 06 club coupe
