Any problem or benefit to putting 305s on my 997S?
I was wondering if it is a good move to put the 305s on the rear of my 2005 997S instead of the stock 295s. I have the 19" Carrera Classic Porsche wheels and track the car about every 2-3 months. Is there anything I should know about mounting the 305s on my car? Benefits or problems to be aware of?
Thanks for the advice,
Flash
Flash
Flash
Flash
Poseur
My 997S Cab will be coming with the XRR rims which take the 305/30x19 tires. The only difference from the other 997S wheels is they are .5 inches wider front and rear. I wouldn't think you would have any issue with such a minor upgrade from 295.
dan
dan
Ahhhh. Good to know. I didnt realize Id need a spacer.
Thanks,
Flash
Thanks,
Flash
Go for it!
Thanks,
Flash
Thanks,
Flash
Thanks for the info guys. I dont see any drawbacks to putting 305s on the rear of my S. I would imagine the car would not only look better but handle better at the track.
Thanks for the info,
Flash
Flash
So if I put 305s on the rear of my 997S with Carrera Classic wheels and 5mm spacers on the front, would everything even out? Is anybody ruuning this setup? Any problems with it? Any pics?
Thanks,
Flash
Thanks,
Flash
i think you can fit 5-7mm spacers all around with your new tires and you will be fine. I think in a few months you will probably even be thinking that the car would look better with the wheels further out. Even though techart and h&r told me it would be ok, i dont think 17 or even 15mm spacers willl work with the 67 offset on the narrow carrera.
i had 7mm all around with 295 rears, no problem
Thanks,
Flash
Thanks,
Flash
