X-51 Update, Interesting Tidbits and Pure Speculation...
I would not be suprised if the x-51 is putting out 407hp on the bench....I would suspect the S engine is putting out more than 355hp....My S cab is noticably quicker than my old 360 spider, which had 395hp and significanty faster than my old 355 spider, which was supposed to have 375hp....
Originally Posted by robbonds
"A couple notes that savvy Porsche pros will keep in mind: engine speeds greater than 5000 rpm are verboten for the first 300 miles (500km). And the maximum engine output of 381hp is only achieved after about 6,000 miles (10,000 km) of driving, since components need time to wear in before friction levels drop and the DME makes optimal adjustments"
if the dme takes thousands of miles to adjust - i wonder if my giac reprogram would work similarly - maybe i need to keep driving it a while before re-dynoing
Any more dyno info on your project?
Agreed. I'm seeing very low 4 second 0-60 times in the C4S, without a hard launch, on a fresh (1400 miles) motor.
I don't want to tell my buddy about this; he just picked up a '98 F355 Berlinetta... <g>
-d
-d
Originally Posted by JFScheck
Availability of X-51 option due to parts shortage
X-51's engines are averaging 407 (give or take a few) on the bench
So I heard while in Germany on a Harley-Project I was associated with a few months back and that's all I can comment...
Originally Posted by MHC2S
JFSheck, hey you work for Harley? My buddy works for them in Kansas City, he use to work at the York plant.
