I have Satellite Radio in my 997 C4S Cab!
Old 10-28-2011, 09:38 PM
  #466
oldskoul
2nd Gear
oldskoul's Avatar
Default Channels not updating... after days...
I have a OLD un up-date-able version for a 08 Cayenne. My unit is not updating the channel list at all. I read on the Navi Tv site in the fourms that many other people have the same problem but there is never a solution posted. Here are the screen shots from my car. Any help would appreciated.
Old 12-20-2011, 11:36 AM
  #467
BlackStrat
BlackStrat's Avatar
My experience:
2007 C2S - upgraded Bose package
Pulled PCM and replaced with Kenwood 6980 and NAV/TV this summer. Setup worked for awhile but eventually audio fails to work - problem was failure of NAV/TV. Pulled old one out and popped in a new NAV/TV. Worked fine for a few months then start car one day and no audio again.
Currently dumping NAV/tv and factory optical amp - rewiring car and replacing with aftermarket amp. Amp is small enough to go where Bose amp sits in frunk.
Old 12-20-2011, 02:13 PM
  #468
mudman2
Moderator !x4
mudman2's Avatar
Mobridge works perfectly in my 08 Cayenne
Old 02-22-2012, 02:32 PM
  #469
dbosche
dbosche's Avatar
You didn't look hard enough. My post (below) indicates that I had a similar problem on my 2009 C2S and resolved it by upgrading the firmware to a patch recently released. My NAV-TV unit is updateable however - do you really have a unit without a USB connection?
https://rennlist.com/forums/8958649-post463.html
Old 02-25-2012, 01:57 PM
  #470
friedma6
friedma6's Avatar
I got a quote to install the Dension unit with the blue tooth module for $485. It sounds real high. Anyone know how long this install should take. The car is an 07 997 with nav and cd in pcm.
Even if it take 5 hours. That is close to $100/hr. Seems a bit much. $250 to $300 seems like where it should be.
Old 02-25-2012, 02:00 PM
  #471
mudman2
Moderator !x4
mudman2's Avatar
That's labor only right ?
Old 04-14-2012, 04:12 PM
  #472
lic265
lic265's Avatar
Just bought a 2007tt with Nav and single cd. I am unclear as to the best option to get satellite radio
Is it 1)using the XM Cayenne kit 2) Using Nav tv kit 3) Using some of Cayenne kit parts as described on 6speed.
Also will add Dension and BT module
Thoughts?
Old 05-30-2012, 02:13 PM
  #473
Powerguy
Powerguy's Avatar
Thoughts?
I just completed this install on a 07 C2S. Very easy installation.
Part Numbers :
955-645-280-02 Satellite radio receiver
955-044-900-65 Harness
Old 06-25-2012, 12:59 PM
  #474
wanderingwheelz
wanderingwheelz's Avatar
With Pandora and the iPod interface connection, why would anyone pay $2000 to install XM when it's music that you are mainly after? I use my iPhone with Pandora all the time even though my 3 month XM free trial is still active.
Old 06-25-2012, 01:06 PM
  #475
mudman2
Moderator !x4
mudman2's Avatar
To get sound quality worth a squat
Old 07-29-2012, 12:25 PM
  #476
love2brace
love2brace's Avatar
I found a great Sirius Satellite unit for 2005-2008 997s. Its called NAV-TV,they have a web site,however I found it at USP Motorsports. $899.00 and about 4+ hrs of torture I have a fully integrated and operational satellite radio. I have a 2006 C4S Cab. The NAV-TV + Sirius unit are small (3"square) fit under the dash. I placed the antenna on the plastic in front of the windshield wipers. The instructions leave a lot to the imagination" but with a few simple hand tools". So far 1 wk it works great.
Old 10-17-2012, 02:14 PM
  #477
bonddaddy
6th Gear
bonddaddy's Avatar
where did they put the antenna on your cab?.....I would be really interested in this setup...
Old 10-22-2012, 09:29 PM
  #478
BeachDoc
8th Gear
BeachDoc's Avatar
This thread was a great read, thank you to everyone who contributed!
Old 11-16-2012, 08:50 AM
  #479
atlast911
atlast911's Avatar
Part Numbers :
Powerguy. Thanks for the PDF...any idea if this will work on my 05 997 C2?
Old 12-14-2012, 01:54 PM
  #480
perfectlap
perfectlap's Avatar
Isn't Pandora internet streaming? That requires data consumption from your phone's plan.
With Satellite for a basic flat fee and equipment you can listen all you want and you don't need to spend $2000 unless the Porsche radio won't work with an aux out stereo plug.
That may be the only thing saving SiriusXM because unlimited data plans are going to become a rarity. The carriers make their money selling data now. It used to be minutes now it's GBs.
I just looked my data usage so far this month, 7 GBs. And I only stream about an hour of video and/or radio a day. Otherwise my Razr Maxx is on wifi where the phone's battery lasts much much longer. Point is it doesn't really take "heavy usage" to blow past 5GB or the even smaller allotment on the typical phone plan once video is added to the mix.
Quick Reply: I have Satellite Radio in my 997 C4S Cab!
