Door card trim
I would recommend to replace it with leather wrapped bezel as well, so you'd only have to do it once. Note that you should replace the trim with a new part, as the old part is plastic welded onto the door card and it will get mangled once taken off. Here is what mine, from exclusive options, looks like.
frederickcook87 (06-21-2024)
Classic 9 Leather carries this at what appears to be a better price point. my E check with a local leather shop and see what they can do.
https://www.classic9leathershop.com/...-bezels-covers
Bob
Bob
Regarding spear, you’re probably best buying them new due to how they’re attached to the door.
Add a small piece of foam tape over eash screw head before.reinstalling the door panel and it will prevent any metallic vibration sounds between the screw heads and the inner metal door skin.
I replaced the spears on a previous 997 with CF ones. There are several really good YT videos on the procedure. The scariest part was melting off the plastic tabs. I don’t remember the screw size but you can search and find it. It will be short, like 1/4” and needs to be a button head or use a washer (like in the photo above)
B911L (07-07-2024)
Speedracer4fi-in looking at the first picture, the new leather on the door trim (spear or door handle trim) looks to be a shade lighter than the original leather. In the 2nd picture, the shade seems to be the exact same as the original. How does it look in person? I have installed some new leather in mine but there is shade difference in some areas. Thanks.
I am attaching a few new picture of my leather door card (taken today) with the leather spear I installed 4-5 years ago. There is still a little difference in shade under well lit room, but the difference is gradually receding as time goes by. You can condition the new leather pieces a few times to speed up the aging process if you like.
