Flood in backseat - Any assistance in the NY/NJ?
HI I have a 2008 997 coupe that has water collecting and rising up from below the rear seat cushion. I have tried to locate the drains - but apparently lack the skill set.
Any one in NYC area that could assist?
I can’t imagine what the shops would charge just to diagnose.
Thanks all.
Thanks all.
Drain hole
drain hole one in each side. Have to lower top and stop in mid range. Pour water in drain and it should drain to the floor. If not then the holes underneath are probably plugged from road trash. Have to disassemble the covers on underside of car to access. Put some towels on floor in back seat as the car electronics are under drivers seat If they get wet it is expen
sive
sive
Sounds like the rear drain line to the sunroof is either clogged or has failed. Take a look at these two threads. Hopefully the line isn't cracked/broken.
Hope this helps,
Bill
DIY: How to clear sunroof and body drains on a 997 Coupe - Rennlist - Porsche Discussion Forums
Sunroof drain tube split open - Rennlist - Porsche Discussion Forums
Hope this helps,
Bill
