Need a Measurement - Motor Mount
Heya, long story but need a measurement for a design I’m working on. Does anyone have a 997.1 motor mount around that can measure the height difference between the two surfaces highlighted in red in the attached picture?
Actually it is a bit more "odd" - I need it because I am putting an LS in a 997 and using the original exhaust. I did a 3D scan of the 997 ending and I have a full 3D model of an LS already. So I need to put the 997 scan in place in based on the orientation of the frame, and then place the LS where it mounts in the same space. I have designed mounting plates for the 997 mufflers and for the LS block - once I have the correct orientation of the other components I can design the connecting pipe for a mandrel bend.
So I need the mount measurement to get it placed accurately.
Goodluck on your project!
