BC Coilovers, anyone?
#61
#62
The adjustments I made were semi minor and I thought sure it would handle all wonky, but it actually seems better, so could I have possibly adjusted everything back into alignment? Haha. I’ll h
ave it realigned in the spring since I’m about done anyway… oil change, powder coating wheels and something loose up front again… probably a coffin arm
#63
I just up the rear by 5 clicks and it is a lot better. Definitely need the alignment done since the front end is all over the place at freeway speeds. Now I’m satisfied with the settings. Still on the fence about raising. I’m planning on doing wheels soon so I think the ride height will match with the type of wheel I want.
in two weeks these BBS’s getting a bright silver spray job.. right now I’m at 5 up front and 7 in back
#64
For an alignment I’ll usually stick the stock wheels on so the nice wheels won’t get boogered up… when I raised mine up I got some positive camber back. The fronts were tipped way in after it settled.
#65
