Anyone ever put 997.1 heads on a 996. 3.4 block?
Hi all and thanks for reading. Here’s my dilemma. I have a 2007 997 that somewhere along the way had the bock replaced with a 3.4 from a 996. The heads are the correct ones for the 997. My issue is that I keep getting a P0016 camshaft code for the bank one camshaft. The camshaft doesn’t seem to be getting oil right away on startup and I’m at a loss as to why.
Before I drop the engine and pull it apart, I was hoping that someone on here may have had a similar issue with this setup and could guide me in the right direction.
thank you so much in advance for your responses!
Thinking you might have more luck posting in 996 section of rennlist if you haven't already?
Petethecarman (07-12-2023)
