Help with no start condition - 997.2 Carrera
I installed my new Battery Tracker in the late afternoon yesterday. (I disconnected (and have not yet reconnected) my battery maintainer.)
Interesting behavior - the battery state/percentage (as reported by Battery Tracker) started out in the low single digits. Over a few hours, it rose to 100%. Is that expected behavior? If not, what does it mean?
Premium Sponsor
Best regards,
Chad(chad@antigravitybatteries.com)
jchapura (04-18-2023)
Hi John, completely normal...as the tracker would just be starting to accumulate data and initializing..and just for a little additional insight. The % value that's displayed is loosely just tied to the voltage reading...so in other words, it's not an accurate representation of the actual capacity of the battery itself..just a helpful tool. The actual voltage reading itself is going to be the accurate value and what you'd really want to go by.
Best regards,
Best regards,
Voltage value - at the same time the percentage value was low, the voltage was reading 12.3V or so. Remember, the battery maintainer was no longer connected. And then the voltage reported by Battery Tracker climbed to 12.84V over several hours (battery maintainer not connected). I found this odd.
Thank you Chad.
Premium Sponsor
Thank you Chad.
Best regards,
Chad
It really has benefitted me with my '87 Carrera. They are known to sometimes exhibit an overcharge condition that can (and often does) damage the heater blower relay. My relay was bad when I got the car. A new rebuilt one was about $400. I needed to be confident that the alternator in my car was not sporadically overcharging - which if it was, would then potentially knock out the new blower relay. Fortunately (and through the use of the AG Battery Tracker), I was able to conclude that my alternator was consistently functioning properly. (And that was evident through the stored historical graphs available in the app.).
The unit also conducts a variety of charge diagnostics - charging at idle, charging at high RPM. Also cranking diagnostics.
For $35, it's a great tool to have.
Given its extended ability through the app to display an historical timeline of readings, for me the benefit extends well beyond that of a simple voltmeter.
Yeah, you are using it as a monitoring tool. Those alternators go bad, I had one suddenly die; it just oscillated for a bit, no secondary problems. I changed the alternator myself - fun job.
@Antigravity
@Ironman88
Part of my "justification" for purchasing my Battery Tracker is because of a special issue I've been dealing with, that is described here: https://rennlist.com/forums/997-foru...when-cold.html
It was suggested that my battery might be bad and that is reasonable since it is so old. Two parts stores load-tested it and it tested OK. Now, Battery Tracker says the battery is OK (although I haven't gone through a crank test yet). When the battery was first being monitored with Battery Tracker and showed low percentage and low voltage - I said "a ha" the battery really is bad. But then it "recovered" in just a few hours to 100% and 12.84V (not on the battery maintainer). I am hopeful to be able to count on the Battery Tracker as somewhat of a diagnostic tool.
@Ironman88
Premium Sponsor
@Antigravity
@Ironman88
@Ironman88
jchapura (04-20-2023)
