PCCM+ DIY Guide
i think the issue is feedback from the Bose amp. Slight white noise with a very slight tick sound. Anyone know if there is a filter or something for this? Could the most adapter be defective?
I turn it ON every time i drive.. fronts low beam, the regular light in the fogunit (not the fog bulb), rearlights, all ON
my only problem is having to turn em ON every drive, and not forget to OFF when done so my battery don't drain.
The DRL as I find out does nothing with the rears, so its pointless. I want rears on at all times, so in fog, dusk, dawn, rain, snow, whatever.. I am always visible at all times.
Its really stupid how car OEM's didn't do this much sooner, and only went that way due to legislation and only halfheartedly(frontsonly) at first
the option is shown in pccm but doesnt do chit on 987c
and on997 no rear lights so wouldny like it that way. I turn the **** ON when i start and OFF after each drive
Totally random. I think its a signals glitch on the most to the ASK AMP
With thanks to MYW and MAXW for tips and suggestions
This is to retro fit a reverse camera, you can find them on Amazon or Aliexpress in various forms.
I would recommend something like this, for ease and clean install
You then only need a small hole for the wire, to mount the camera on the ledge above your license plate.
and drill the hole in the horizontal upside down bit of your bumper, so it never becomes an eye sore if you ever decide to remove the camera.
RCA signal goes to the fakra connector
But you need a reversing signal to the PCCM so PCCM knows when you are in reverse and need the camera.
That one has to be installed on PIN 6 of the white 6 pin connector :
Green wire on the corner near the blue GPS antenna is the reverse trigger
Apply 12volt and presto PCCM turns on the reverse camera view.
Complete diagram:
Option 1 Splice Reversing light in the rear (typically black cable blue stripe)
use that to power the Camera with 12v and send trigger back over the RCA cable to pin 6
Option 2 Pin 8 can be used to power the camera
When 6 receives 12 volt, it will switch on 8 for the camera power
This requires splice the cable loom near the fuse panel in the front , drivers side footwell
and send power back from PCCM to the camera over the RCA cable
To test
You have to perform the PCCM auto configure with camera powered and pin 6 triggered
During the autodetect, it will acknlowledge 'Rear view Camera detected" and after finishing the auto detect, from then on , each time 6 is triggered you get audible click as it switches over to the RCA feed
If no feed it displays an orange camera symbol, with trigger audio volume is also reduced when it switches over to the camera.
Wire snaking to the rear
Both 987 and 997:
go from back of pccm, snake via the center console to behind the front seats
In practice you might get this done without dismantling anything. the Center console verticable plastic bits overlap the carpet on the tunnel
But it is not bolton on in that area.. So you can pretty much stuff the cable up there as you go along.
997 and 987 differ for obvious reasons.
987 I suspect is the easier one of the because you can just go over the engine bay, inside the cabin.
Remove the 2 engine carpet covers, and you can snake it behind that, below the front engine lid, then over the top engine lid.
With a wire puller you can easily go around the shock tower and presto you are at the rear light.
I cannot comment for 997 not done it myself, but MYW has this thread to explain it :
https://rennlist.com/forums/997-foru...l#post17572285
Camera rear bumper install
997 report is you can install a camera without taking the bumper off
987 no such luck there is no access to rear of the bumper due to heatshields, it will have to be taken off to install the camera and wiring from the rear.
1 take off rear lights
https://www.youtube.com/watch?v=7kuJXBGIZwg
2 remove rear spoiler
https://youtu.be/cclsxeDRjls
3 take off bumper
https://www.youtube.com/watch?v=1W3oVkyrolQ
I checked the power on there connector and get 12v
The pins seem off. The green pin does not have connection on the pcm side. The yellow wire has no connection. I am aiming the each wire should line up to the same color on both sides
