Center Lock Wheel help
Should be called a PCCB Conversion Kit as it provides rotors the same size as the PCCB ones and iron rotor compatible pads. So uses the PCCB calipers with new iron rotors and pads which is what's shown in the photo. With PCCBs the rear caliper are 4 piston and the fronts the larger 6 piston.
So people buy these kits if they'll be tracking the car so they can use and destroy much cheaper steel rotors. Rennline sells a caliper stud mounting kit for these folks so they're not constantly unscrewing and retorquing caliper bolts into the aluminum uprights and can just slide the calipers on and off the studs.
Or, they're bought by someone who has work out or damaged the original brakes and wants a more economical solution to keep the car on the road.
It's a better setup than the stock iron brakes because you get 6 piston front calipers instead of 4 and they offer a 2-piece Girodisc rotor option so you can have reduced unsprung weight vs a normal 1-piece rotor.
Basic Sponsor
Benefit is not to destroy the very expensive PCCB rotors if tracking the car. A new replacement rotor from Porsche is almost $10,000 and ironically, these brakes that were designed to be fantastic on the track are, but don't last very long and are ridiculously expensive to replace. Second consideration is that they're easily damaged by ham-fisted repair shops if you're not very careful about sliding the wheel away from the car on 2 of the guide pins. If the wheel drops and contacts the rotor, it will chip the edge.
-Rick
HINZ MOTORSPORT
Race Parts & Accessories for your PORSCHE
www.HinzMotorsport.com
Call: 414-212-5679
Email: rick@hinzmotorsport.com
-Rick
HINZ MOTORSPORT
Call: 414-212-5679
Liste-Renn (01-20-2023)
You can use the PCCB calipers with steel rotors - they are just calipers after all. but you need to use pads designed for those rotors. I cant imagine a scenario where you would use the steel rotors with the PCCB's - but again if you have steel rotors that fit, as long as you use the pads designed for the PCCB's it would work as normal.
For my part, when I get a little time I am going to put the PCCB's back on my car to see how they compare to the Steel 350mm rotors that were supplied with the PCCB 'delete' kit - which by the way, work very well.
The following 2 users liked this post by user 6290283:
Liste-Renn (01-20-2023),
Petza914 (01-20-2023)
Basic Sponsor
Thanks Pete. Maybe I misread what was posted by someone previously but I got the impression that you can use PCCB calipers with steel rotors or use steel calipers with PCCB rotors. Whichever combination works best and brings the most bang for the bucks. Where did I get it wrong? I thought PCCB rotors went with PCCB calipers and there's no mixing either one up with the steel options.
Forgot to mention, if you are doing aftermarket 2-piece iron discs from Girodisc, PFC, AP etc, the pad used will normally be pointed out in the listing if different than stock, so pay attention to that as they may use a different disc sweep requiring a different pad shape. This is most common when the kit upgrades the rotor size from stock.
The following 2 users liked this post by Hinz Motorsport:
