997 Suspension Mods with Coil Overs Aggressive Drop
What are required suspension components when aggressively lowering the car? I've noted the following, but not sure all are needed for street use only:
(1) F Bump Steer Kit; (2) R Dog Bones; and (3) R Toe Bump Steer Kit - all needed for proper alignment?
Thanks in advance of your helpful thoughts?
Is the rear tow links to adjust the camber and tow? If you want to lower it to no finger gap...is the rear tow links needed? I would assume stock rear camber would probably be around -2.5 range when lowered to no finger gaps.
My car is lowered at near to 1 finger gap (barely) and my adjustments are maxed out and I’m wearing my tires quite rapidly <5k miles on rears with the inner worn to safety bars. Hence, this thread.
Ed99 (07-30-2022)
What kind of tires are you running? 5K is premature, but many high performance tires wear quickly.
That looks like one perfect 997 stance right there!!! All 997 should be sitting like that. Do you have any close up shots of the tires and fenders? Would like to see if there is any finger gaps at all haha!!!
