Were there any warning signs of your PDK failure?
I'm not having any PDK issues with my 2010 997.2 but just was curious this morning for those who have had a PDK failure. Were they any warning signs?
Not PDK, but my Audi DSG did not have signs prior to failure. Always serviced on time.
I own a 997.2 that suffered PDK failure under prior owner and there was no warnings as far as I know, just a sudden message and the dreaded illuminated (!)
rlshaw (11-13-2021)
Not having any issues, so why the heck even worry or think about it. Common sense and a quick search will show some had intermittent problems before hand and other had zero problems before hand, but why even go there with your mind and then feed the neurosis on here if you have NO issues?
The following 3 users liked this post by Doug H:
In the second case the light wouldn't clear but I was able to drive it to the dealership where they diagnosed the nature of the warning. Can't remember the fault codes but like the first failure the second failure was traced to an internal electronic component so therefore full replacements in both cases. Both replacements covered by extended warranties. The second one was on my GTS and the tab came to $25,000. Only paid the $500 deductible to Fidelity.
rlshaw (11-13-2021)
No issues. Went to do the 12 year service and noticed a small amount of fluid. Turned out it was a leak from a bad seal. Only way to fix was a new transmission.
Car drove exactly the same before and after
rlshaw (11-13-2021)
I would argue that the "warning sign" would be the actual failure.
In other words, dash light on? Something has failed. Shifting funny? Something has failed.
Unless you're thinking of some sort of omen like a black cat walking across your path or an inexplicable feeling of dread when you start the car...? LOL
Seriously, most failures are sudden and catastrophic; something internal breaks; it's not like a clutch starting to slip. Do your service, drive the car, don't sweat it.
rlshaw (11-14-2021)
If you are looking for something to worry about I'd suggest the pending global supply chain collapse and runaway inflation destroying your life's savings are more worthy subjects. Or you can live your life and be happy.
Fined (11-13-2021)
I should add that I have yet to read or hear about a mechanically related PDK failure. Only electronic related failures. Doesn't mean the mechanical portion of the PDK is fail proof but based on the lack of stories about such failures they must be rare. FWIW, my service advisor at the dealership said he hasn't seen one single mechanical PDK failure since the PDK was introduced in 2009. All failures he's seen requiring full replacement have been due to internal electronic components.
rlshaw (11-14-2021)
To my understanding, there is no meaning between fluid replacement or timely maintenance and prevention of PDK failures.
99% of the failures observed in PDK were found to be related to electrical failure.
In fact, there are many cases where after a fluid change in the PDK an electrical fault was observed (following incorrect calibration of the PDK).
Thankfully, thanks to the amazing people in the forum - there is hope for a PDK repair (without the need for a full PDK replacement).
The only thing I can think of that can help maintain the PDK and clutches is:
1. If you live in a hot country - make sure you have a third radiator, for PDK cooling.
2. Do not overload the clutches: Try not to be in position D while you are in parking lots or traffic jams (avoid overloading the clutches - and abrasion of the clutch). Stay in M position and do not downshift while the foot is on the declaration.
Another thing, try before you drive hard to wait for the PDK to set to working temperature. This is true for any engine or transmission system based on hydraulic oil / mechanical components.
My 2 cents
My 2 cents
rlshaw (11-14-2021)
Proactive, nah. Nothing you can do to prevent the failure even if it hiccups before catastrophic failure. Some guys have reported intermittent shifting/sticking issues prior to failure that may have reset when turning car off and back on.
keep us posted on how it goes.
i just suffered a likely PDK sensor failure in my 997.2 a few days ago (posted on the PV997's main PDK repair guide thread), so I'm curious how it is going to turn out for you...
