PSM error + Check Engine
Old Sep 24, 2021 | 02:31 PM
VVayfarer's Avatar
VVayfarer
Default PSM error + Check Engine
Hi all,
maybe someone will be able to determine from the graphs?
This is the schedule of a 5-minute trip. During the trip, Check Engine + PCM error was triggered 3 times
I am confused by the jumps on the Throttle position chart.. aren't they too high? it feels like errors fly out at the moments of these jumps on the chart. this is a 5-minute ride without sharp accelerations, just a warm-up ride (although on a hilly road).
There are the remaining 60 graphs that obd2 reads, I can supplement
Old Sep 25, 2021 | 08:12 AM
Petza914's Avatar
Petza914
That looks very odd. What do the codes from the CELs say. Anything aftermarket installed like a Sprint Booster or similar?
Old Sep 25, 2021 | 08:16 AM
VVayfarer's Avatar
VVayfarer
the car is completely in the factory configuration
absolutely no tuning
Car Scanner ELM OBD2
DTC report
Selected brand: Porsche
============1==============
P0172
Raw code: 0172
ECU: Engine control unit
Status: Pending
OBDII: System too rich, bank 1
============2==============
P0301
Raw code: 0301
Status: Pending
OBDII: Cylinder 1 - misfire detected
============3==============
P0302
Raw code: 0302
Status: Pending
OBDII: Cylinder 2 - misfire detected
============4==============
P0303
Raw code: 0303
Status: Pending
OBDII: Cylinder 3 - misfire detected
============5==============
P0300
Raw code: 0300
Status: Pending
OBDII: Random/multiple cylinder(s) - misfire detected
============6==============
P1638
Raw code: 1638
Status: Pending
OBDII: Can Link ECM/INSTM Circuit / Network Malfunction
============7==============
P0172
Raw code: 0172
ECU: 01. Engine control unit
Status: Pending fault present during this driving cycle, Test has not been completed, Validated and stored in non volatile memory, Validated fault present at time of request
============8==============
P0301
Raw code: 0301
Status: Pending fault present, Validated and stored in non volatile memory, Validated fault present at time of request
============9==============
P0302
Raw code: 0302
============10==============
P0303
Raw code: 0303
============11==============
P0300
Raw code: 0300
============12==============
P1638
Raw code: 1638
Status: Pending fault present during this driving cycle, Validated and stored in non volatile memory
============13==============
P2800
Raw code: 2800
Status: Test is inhibited by other DTC, Test has not been completed, Validated and stored in non volatile memory
OBDII: Transmission range (TR) sensor B - PRNDL input
============14==============
B2C12
Raw code: AC12
Status: Pending fault present, Test is inhibited by other DTC, Test has not been completed, Validated and stored in non volatile memory, Validated fault present at time of request
============15==============
P1C0B
Raw code: 1C0B
============16==============
C3202
Raw code: 7202
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory
============17==============
P0038
Raw code: 0038
Status: Pending fault present, Pending fault present during this driving cycle, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault has been present during this drive cycle
OBDII: Heated oxygen sensor (HO2S) 2, bank 1, heater control - circuit high
============18==============
C177C
Raw code: 577C
Status: Pending fault present during this driving cycle, Test is inhibited by other DTC
============19==============
P0103
Raw code: 0103
OBDII: Mass air flow (MAF) sensor/volume air flow (VAF) sensor - high input
============20==============
P0128
Raw code: 0128
OBDII: Coolant thermostat - coolant temperature below thermostat regulating temperature
============21==============
P38C1
Raw code: 38C1
============22==============
P0301
Raw code: 0301
Status: Pending
============23==============
P0302
Raw code: 0302
Status: Pending
============24==============
P0303
Raw code: 0303
Status: Pending
============25==============
P0300
Raw code: 0300
Status: Pending
============26==============
P0301
Raw code: 0301
============27==============
P0302
Raw code: 0302
============28==============
P0303
Raw code: 0303
============29==============
P0300
Raw code: 0300
============30==============
P2800
Raw code: 2800
============31==============
U0823
Raw code: C823
============32==============
P3201
Raw code: 3201
============33==============
P0001
Raw code: 0001
OBDII: Fuel volume regulator control - open circuit
============34==============
P0038
Raw code: 0038
Status: Test is inhibited by other DTC, Validated fault present at time of request, Validated fault has been present during this drive cycle
============35==============
P2379
Raw code: 2379
============36==============
P0103
Raw code: 0103
============37==============
P0128
Raw code: 0128
============38==============
P38C8
Raw code: 38C8
Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC
Old Sep 25, 2021 | 08:28 AM
Petza914's Avatar
Petza914
Year and model? Has the car sat for a period of time where the battery might be low? If you hold the throttle mostly steady do you see the same Throttle Position Sensor spikes. Do the MAF readings jump around on their own? I'm thinking it's a low battery, MAF failing, or Throttle Position Sensor failing.
Old Sep 25, 2021 | 08:46 AM
VVayfarer's Avatar
VVayfarer
997.2 turbo , year 2011
the battery was replaced with a new one, after that all the errors were reset many times. But the errors come back after a short ride.
Usually it is a misfire of 4-5-6 cylinders, sometimes on the contrary 1-2-3 cylinders. Once there was a misfire 1-2-3-4-5-6.
+ a set of random errors that changes from time to time.
First of all, I changed the MAF. Without results. In addition, if MAF is disabled completely, then this does not help either.
Now I have changed the throttle to a new one. And this also did not change the situation in any way.
Another of the symptoms. When the engine is cold, the engine speed floats when warming up. After warming up, they are stabilized.
sorry for my english
Old Mar 20, 2024 | 07:51 PM
maxgboy8's Avatar
maxgboy8
Default Did you find a answer to your problem
Hello, was reading your thread I’ve come across what seems to be the exact same problem as you. I’ve replaced all the same parts as you to the same result no change did you ever figure out what was wrong. Kind regards maxwell
