PCM 3.0 Integrated Wireless CarPlay/ Android Auto
Old 06-03-2021, 01:16 AM
  #76
Hatzenbach
Hatzenbach's Avatar
Here is what I would do
lets make sure the camera works: do NOT connect the single red wire to the purple wire, but connect the black wire to ground and the red wire to +12V
plug in the yellow plug in the rear camera plug of the CarPlay harness
put the car in reverse you should see a picture from the camera
if that doesn’t work something else is broken or misconfigured
After that disconnect the camera and do that
if you have a multimeter then measure if the two red wires (on both ends are connected, they should be)
I just remember: did you set the rear view camera to “aftermarket” in the setup screen?
Old 06-03-2021, 06:14 AM
  #77
whacko77uk
whacko77uk's Avatar
Here is the software setup video;
Old 06-03-2021, 02:14 PM
  #78
larrytrk
larrytrk's Avatar
are you connecting the camera to backup rear light for the 12 volt with NATIKA camera and the purple for activation by CarPlay? Plus ground.
Old 06-03-2021, 04:05 PM
  #79
Hatzenbach
Hatzenbach's Avatar
That wouldn't work. It's either one or the other
Old 06-03-2021, 06:40 PM
  #80
larrytrk
larrytrk's Avatar
just talked to Nick, the purple CarPlay wire is 12volts, so that is all you need.
thanks
Old 08-01-2021, 12:54 PM
  #81
AmericanSuccess
AmericanSuccess's Avatar
Do any of you have a video of this in action? Is it reliable to use? Many Thanks.
Old 08-01-2021, 01:16 PM
  #82
Hatzenbach
Hatzenbach's Avatar
don't have a video, as there are many videos about it on YouTube
I have it now for ~2 months and it's very reliable. I had only one incident so far where the wireless connection dropped
Old 08-01-2021, 02:59 PM
  #83
larrytrk
larrytrk's Avatar
No video, just picture.. didn’t cut extra wire on camera so have both grids..the unit grid moves with steering wheel.
myw (10-15-2021)
Old 08-01-2021, 03:02 PM
  #84
AmericanSuccess
Thank you for the reply. Good to hear it is reliable!! I'll check out YouTube.
Old 08-01-2021, 03:03 PM
  #85
AmericanSuccess
Thank you for the picture, how does the camera look from outside?
Old 08-01-2021, 03:13 PM
  #86
larrytrk
larrytrk's Avatar
Camera plus Hopkins backup sensor system. Please excuse crooked plate mounting….
Old 08-01-2021, 04:00 PM
  #87
AmericanSuccess
Looks nice and neat there like it could be OEM. Thank you.
Old 10-14-2021, 02:05 PM
  #88
eaks
eaks's Avatar
Hey guys,
I am picking up my 2009 turbo this weekend and I have a bluetooth transmitter for my drive back (14 hours). I am looking at doing this carplay upgrade although from everything I thought I had read installation of this unit essentially disabled all the PCM features and was only able to use carplay (seems it just used the screen and the buttons).
Rereading this thread this may be correct and it is possible to go back and forth between the stock PCM setup and the carplay (long press of info?). If this is the case I am going to get this for sure and wire in most likely a front and rear camera (only front as I will be doing a laser blocking setup as well).
So basically I would like confirmation that all the original PCM features are still accessible and functioning with this unit? If it isn't can you let me know what features I will lose from the PCM3.0 by going this route?
Thanks guys
Old 10-14-2021, 02:21 PM
  #89
JVinPortland
JVinPortland's Avatar
Confirmed. You can still use all of the PCM functions; can toggle back and forth with Carplay.
  #90
doclouie
doclouie's Avatar
Originally Posted by eaks
Hey guys,
Thanks guys
This mod is on top of the original PCM. You will not lose any standard features. I have run this mod for about a year now and love it. It is a little not involved, but not bad.
Quick Reply: PCM 3.0 Integrated Wireless CarPlay/ Android Auto
