Mezger turbo!
#76
We're pulling for you, hang in there. I'll never forget a long time ago my car broke down and I ended up dropping the fuel tank and replacing the pump on some shabby North Hollywood street thirty miles from my house. I couldn't afford a tow truck back then so I went for it. Had it on jack stands and was draining fuel in some strange neighborhood where I didn't know anyone.
Long story short everything worked out okay but it's not something I would ever do again. Get this behind you and enjoy the car, the turbo truly is special.
thats awesome haha 😂💪🏼
#77
What could be in here? 🧐🤪
#78
Picture is garbage, plz excuse the quality lol
gt3 rear carpeting
#81
so i sprung a massive coolant leak : )
that sucks
but, the brace is “in” still needs 2 more bolts. But it should hold the motor, for the 2 blocks to get it into the shop and finish what i have started.
#82
The following 4 users liked this post by bronz:
#83
Did you crack the coolant pipe having the edge of your jacking board underneath it?
Did you use the sunglasses as a cushion between the board and pipe?
roddylennox (04-20-2020)
DanielW (05-22-2020)
#85
car should should be in the shop in next day or so for the following
gt3 carpet install
rear pads/rotors
fwd system removal
fix coolant leak
swap the rsr brace for proper gt3 cup brace
install straight pipes.
#86
I haven't used the sawzall in days lol, I'm not sure why the coolant leak occurred.
gt3 carpet install
rear pads/rotors
fwd system removal
fix coolant leak
gt3 carpet install
rear pads/rotors
fwd system removal
fix coolant leak
#87
you are correct. I thought it was one piece, it was not. Should have been supported on both sides. I will have to give it some more inspection once i get it on the lift.
#88
You only want to pick up on the case with a notched block to prevent damaging the casting or other things. You will want to most likely pull both the coolant housing and water pump housing off the motor to inspect for cracks.
#89
And possibly weld the coolant fittings in if that hasn’t been done to the car already.
#90
fittings have already been welded, im pretty bummed right now with this coolant leak. Something tells me i will be pulling my motor in the next few days to make sure i didnt fck it all up🙁
