HPDE and stock brakes
Hello,
2005 c2S is new to me. I have many years of track experience and racing. My intent with the C2S is a street car that I can OCCASIONALLY drive to bucket list tracks and do a DE on street tires rather than trailer my race car to it.
Question: Do the OE brake pads and Fluid do a good job for this? I would rather not go down the road of getting spares for this as it will be 1-2 times a year. If I need to swap pads then so be it but I have coached a number of students with cars like AMG MB or Corvettes that did DE’s on stock set ups and the pads remained meaty all day.
The stock Textars are “OK” on the track, they will fade if you are pushing hard. You need to change the fluid occasionally anyways, so I would probably go with something better than stock, like Motul. Have fun, what tracks do you want to run on?
Tracks: Barber, VIR, Watkins Glen, Road America, COTA, Mid-Ohio
Anything farther from MIami I will just rent track side.
Miami, I track motorcycles close to 20 weekends a year, but hadn't tracked a car in probably 10 years. Bought the 911 in December and first track day was in March. With your experience, you will need new pads and fluid, at the very least. After the first session, getting comfortable with braking points, I was already cooking the pads and having lots of fade, this was at NCCAR; which doesn't have a super long straight. I was actually disappointed in the stock setup. I'd also add that the GT3 brake ducts are cheap and probably a great addition as well.
Specifically, if you're gonna drive up to VIR, a home track for me, that front straightaway is long and fast. And if you're on full course, the backside straight is also long and fast.
Cw
Cw
I have a case of Motul 660 so no worries to flush the fluid. All the pads I use for racing are corrosive and brutal on rotors (hawk blue, carbotech xp12) so I would rather finds a compromise pad if I am going to buy another pad. Something I can drive to the track with and not so hard on rotors. I will be on street tires and will of course push a little but not like I am trying to run personal best laps on timer. Any suggestions for a compromise pad?
Thanks guys. Will explore the Forodo pad. If not does anybody suggest a good track pad? Always hear Hawk DTC 70 are a good feel/ less dusty but that’s for a spec Miata. Don’t know what the favorites are for the 911 track crowd for a street driven/steer tire car.
I am not a big fan of those insane long straights. I have seen the carnage. I know both VIR and Road America are big dog tracks and you see it go terribly wrong with the professionals there.
PFC 08's
Both squeal on the street.
On a positive note, earlier this year they installed a SAFER barrier at the kink at Road America.
Moreover, since you're in a .1 like me, you'll likely need to make some additional changes if you want to ensure you're driving home after the weekend.
Oil pan baffles
3rd radiator.
Function first or similar cable attachments to the transmission.
Cw
Oil pan baffles
3rd radiator.
Cw
Oil pan baffles needed for street tires?
I guess it depends on your tires, these new tires are sticky! and how risk adverse you are. There are reports on this forum of people having the oil light come on during long hard corners...
Something to consider.
I did the x51 baffle for occasional track use. The sump is super easy to drop.
I used OEM pads at Mid-Ohio in the spring when I had it out on a whim. I certainly had to remain aware that I had stock pads and the car wouldn’t slow like my S2k on race pads, but it worked to just have fun. I am heading back to mid-Ohio in October and plan to take the 997, I will just use OEM pads.
