Rear Emblem
#31
Pete - pretty sure we're talking about the same guy. Jim @ carreraeast I like the ones you have had made.
You think the "all blue" is too much ?
#32
911 badge
I chose to go "vintage" with an OEM 911E badge. I cut off the E and the mounting pins and attached it with 3M badge tape. Put it on about 5 years ago. It is a little small for the car, but I like the classic Porsche font.
Classic 911 badge on 2010 C2.
#33
I agree that black would look better especially with the darker tail lights. Otherwise the red of the lights would marry it.
#34
I think the all blue won't look as good as the two-tone. I've seen all black cerakote on a black car and didn't like it as much. The second color should match the wheels or inside headlight color or similar to tie it all together.
This is what I did on the Cayenne where the silver body accents go with the headlight insides and why I chose silver wheels.
myw (07-14-2019)
#36
I prefer the original silver color on a dark car and black on a light colored car. I don't really like the mixed silver with red "S" so much. I thought about doing it because I have black and the red actually looks pretty good on the black but I kind of like the original silver. I like some of the originality here when it comes to changing the actual wording etc. but again, I'm just liking the purist look.
anewman (07-26-2019)
#37
Plasti dip rear emblem
Plasti dipped Carrera black and S red
I modified my emblem with black and red plasti dip. Th black Carrera goes well with the black paint, better than the brushed metal look of the original emblem and I like the pop of the red S.
Gmanscott (07-15-2019)
#38
the problem with the aesthetic on this one is that it isnt executed correctly
- the P O R S C H E letters are measured from the top of the decklid here - if you look at the car from the back the word will be slanting downwards (frowning)
- Carrera is a tad too high
- the S was put on as an after thought, without repositioning the Carrera to the left
- the red S is 997 sized, its around 30% larger then the 991 sized badging and is out of alignment
alot of creative ideas can work, they just need to be executed properly via an oem, cleaner, lined-up approach imho.
#40
Magnus Rostadmo (07-21-2019)
#41
As I said, that's a bit ridiculous, so feel free to do whatever you think looks good.
#42
Meanwhile, my 997.2 has the stock "Carrera 4S" badging, and I intend to keep it. It's not about looks, really, but identification. If someone sees a 911 and doesn't immediately know it's a 911, that person also doesn't care. So the straight 911 badge doesn't do anything functional. Same story with the P O R S C H E lettering. By contrast, I regularly see a 911 and wonder which sub-model it is; the badging quickly explains it to me and I can be all like "oh, a 4 GTS...nifty" or whatever.
That said, lots of the examples above look great. Do what you feel...
#43
+1. I like the stock badging on the c4s . Not too much- not too little. All in one line, and seems to balance well....
#44
Forgive me for a totally silly concern about your crest quest. But I would note that the crest is a combination of two coats-of-arms, and that color is quite important in heraldry. If you go changing the colors on the crest, it just fundamentally isn't the Württemberg-Hohenzollern + Stuttgart design anymore.
#45
