Locking Just The Trunk
Is it possible to just lock the trunk without locking the doors? I've got a cabriolet and I'm used to being able to lock the trunk on convertibles while leaving the door unlocked, so I have a secure storage space while not risking some idiot cutting the top to break into the car. If not, is it possible to require the trunk release switch so that it only works when the ignition is on.
If you lock a cab, the alarm goes off if anyone tries to open the door, frunk or glove box. I believe locking the car also disables the frunk release, doesn’t it?
All true, except the alarm does not go off when the car is locked and the door handle is tried. The concern here is that an idiot will try the door, find it locked and go after the roof with a knife. I've always just left convertibles unlocked and locked anything of value in the trunk to prevent low lifes from cutting the top to try to get in.
I'm not aware that this is possible, however if you unplug the wires to the frunk release switch on the driver's inner door sill, I think the button on the key will still pop it, but the switch won't work anymore. Maybe this achieves your objective and will still let you lock the doors whenever you wanted too
Yes, the frunk release is disabled when the top is down and the doors are locked so even if you don't open the door you can't get in the trunk. All of this is fine, but has nothing to do with removing the incentive for a dummy to cut the roof trying to get into the car while the top is up and the car is locked, which is what I'm trying to figure out a way to avoid, while still being able to have secure storage in the trunk.
Ah I see. I thought you wanted the frunk secure when parked with the top down. I didnt read closely enough to see you want to leave the top up with the car unlocked but the frunk secure.
Yes, that's a difficult one. I'd consider disabling the interior trunk release. The frunk switch is a simple circuit. You could splice in a wire and hide a switch somewhere (locked in the glove box, perhaps) so you could disable the switch whenever you feel like it, then enable it at will.
