PSE Install - To Button or Not to Button?
Leaning towards installing PSE on my 997.2. Cost is extra $1500 for the on/off console button.
For those that have installed PSE, anyone go forward without the button? Is it obnoxiously loud all the time?
I really want the sound. I am pretty certain based on what I have heard, that I would likely always have the button on. So it makes sense to just forgo and not have to turn on, or drop an extra $1500.
Minor concern is that in them installing the wiring etc that somehow I would be left with squeaks or rattles inside?
Any comments would be appreciated.
The original owner of my car bought new from P and paid $122 k and got everything BUT PSE. Figure that out if you can.
I added it after i bought the car in 2016 because I thought it was an option it should’ve had. Two thoughts for you......
- Why bother at all adding PSE? There are a number of aftermarket exhausts that sound better than the lame PSE and you’re going to leave it on all the time anyway.
- If your heart is set on PSE put the button in and do the job right. For cosmetic and resale explanations if nothing else.
With hindsight I would’ve gone aftermarket and skipped the $2,000 ‘ish PSE refit. Not worth the money unless added as an option new.
I put a on/off button in my ashtray, direct wire to the fuse box, for complete control of the exhaust, bypassing the car control.
works well, no problem. Test your solenoid with a 9 volt battery for on off of Sport exhaust.
I did it to both my 06S and my 09S!
I added PSE on my '16 Cayenne Turbo. I would add the button for two reasons. First, as "mike cap" says, it will help resale. You own a Porsche, don't skimp on the the upgrades.
Next, you could get along with exhaust without turning it off, I think mine sounds like stock until you place it in Sport or Sport Plus. But there might be a time you'd just want to turn it off, especially when you have someone riding with you that isn't as ecstatic about sports cars as you or you want to be considerate to your neighbors.
If you wanted to have saved money, you should have bought aftermarket.
I won't get into all the details but only looking at stock PSE. I understand it might not be the best option, but it is the one I have decided on. I might add the Fabspeed X Pipe, but exhaust system will be PSE.
If you’re so hung up on the OEM route then spend the money and do it right with the console button. If I was buying a car with PSE and the owner told me he was too frugal to install the switch mechanism I’d think it quite odd and make me wonder about the car.
good pt. Actually considering not installing it because I truly dont see ever not having it on. So why? But then this is a good pt I guess as well. Do it right and no flags I guess down the road for other owners.
Does anyone know if the PSE on the 997 closes the valves at certain rpm ranges even when active to reduce drone? I know some of the newer models of 911 do this. If that is the case, I’d suggest leaving the system disconnected for the full open effect.
Don’t bother with button..
Nic, I’d vote to not bother with the button. I went with PSE on my 997.2 for the sake of keeping the aesthetic as close to OEM as possible and contemplated installing the button in the console as well but ultimately decided it wasn’t worth it. Full disclosure, I also added a center muffler bypass at time of PSE upgrade. That said, it’s always in “loud-mode”. But even as such, I can tell you that the PSE exhaust is still quite docile sounding compared to other aftermarket options. The cold-start is a bit loud for about 30secs, but levels out to an acceptable (docile) note at idle. Definitely get yourself a center muffler bypass - otherwise, you won’t notice much of a difference between regular or PSE.
Feel free to send me a private message if you need some visual / audio examples.
Subjective topic but if you look for better exhaust sound you're wasting your money unless you're getting rid of the center muffler too. The PSE with the center muffler left in place won't make much difference. I have the Sharkwerks pipes and the sound is killer along with the PSE mufflers https://www.sharkwerks.com/c_exhaust-f_carrera_g_997-2 Not disturbingly loud at all until you get past 4,000 rpm and even then, it's not past the point that I think it would bother anyone. Just right. There are several other options on the center muffler delete, all of them $1,100 and below.
Please don't spend all that money on the PSE unless you're ready to address the center muffler too. It's heavy, very restrictive in terms of sound and will reduce the money and the result you expected from what you invested in the PSE . Just my opinion. I think you'll be well advised to ask for other's before deciding where you want to go.
Just read through the Suncoast page again. It's a bit ambiguous as to whether or not it makes a difference if you have sports chrono or not. May have to call to clear up.
I definitely think I am leaning towards the Fabspeed x pipe delete with the PSE. Reading these last comments seem to echo that this would be the best decision. Thanks for the feedback.
ps Winnebago I sent you a PM as well.
my 2 cents....
First thing I do after starting the car is to put it in loud mode. I wish there was a way to have it default to loud. Even in the PSE mode it's not obnoxious so I wouldn't worry about pissing off neighbors unless you intend to floor it in residential neighborhoods.
So, if I had to pay an extra $1500 for a button I would skip it.
my 2 cents....
