6 month or 12 month Oil Changes
I don't get oil analysis ? ? What's the purpose ? ? Use good oil and change it every 5000k or sooner if necessary ..pull the old filter apart and check for any undesirables and you are good to go. Porsche engines are hard on oil just like sport bikes and jet skis. I need to see fairly gold color oil coming out at oil changes, as contamination / delayed oil changes are more of a threat to our engines.
Here's a post. I put into the 928 forum this week when asked the same question
I use Blackstone's bulk order service and pay for the TAN and TBN to be added as that shows you how acidic the oil is becoming - you want the TBN to remain higher than the TAN.
To answer the what's UOA good for,
- it can detect issues with the engine prior to a major failure that would then cost more to fix.
- It can detect the presence of coolant in the oil from a leaking head gasket or fuel in the oil from a bad injector or from lower compression in one cylinder,
- The presence of various wear metals like iron, aluminum, and copper that can tell you if something is wearing badly like a main bearing or a cylinder scoring process has begun.
- Will show silicon levels which is pretty much dirt that can point to unfiltered air getting into the motor which could be a vacuum leak or a poor air filter.
- Provides data on viscosity and flashpoints that will tell you how well the Multi-grade additive package is holding up so you can adjust your oil change interval accordingly
- Gives you levels of Zinc & Phosphorous (ZDDP) that protect the valve train - you want 1,000ppm or more of both
- and some other things
Former Vendor
A lot of these oil change intervals people are suggesting are a bit extreme- a 1 year, less than 5K mile oil change is a good practice on street driven cars by the way even though a bit conservative. Especially considering the sump size in your Porsche's, they have the potential to go quite long on oil changes if monitored correctly.
A UOA will help you understand the health of the oil (and your engine). You can then base your drain interval on tangible data instead of just coming up with random time/mileage estimates based on what you feel comfortable with. -Nick
One time a year for me, which is about 2-3k miles.
Because the advice in the manual doesn't put the car first, it puts the owners and marketing people first. When people are comparison shopping, they'll wonder why they have to change the oil in their Porsche every 5,000 miles when the BMW or Audi says they can go 10,000 miles. No ICE car should ever go longer than 5,000 miles on an oil change, unless they just don't care about the longevity of the engine (leased car), especially a high-revving, higher HP motor, like in the 997. Anyone who does UOA can see breakdown of the additive package in as few as 3,500 miles on a car that's frequently driven in a spirited fashion. By 10,000 miles, your 5W/40 is probably 0W/20 not to mention how dirty and acidic the oil has become from absorbing byproducts of the combustion process.
