Brake Job Gone Bad
found this on autoanything.com. seems reasonable. thoughts?
Brake pad bedding is an important process that removes impurities from the surface of the brake pad and lays down a thin layer of pad residue on the rotor surface. This is accomplished through repeated heated and cooling during braking. These cycles are like Goldilocks and the three bears: temperatures need to be just right to prevent scarring of the brake pad and rotor surfaces, or uneven pad transfer. Follow these easy guidelines and enjoy quiet, smooth and long-lasting braking. While every manufacturer has a different method for bedding in their brake pads, the basics remain the same—regardless of brand.
- Find an open stretch of road that will allow you to safely stop your vehicle multiple times
- Accelerate to 35 mph and apply moderate brake pressure to reduce your speed to 5-10 MPH
- Repeat this process 3-4 times, the goal is to warm up your brake pads
- Now turn up the heat even more by increasing your speed to 45 mph and braking down to 10 mph
- Pro Tip: It’s important to avoid coming to a complete stop during this stage as it’s possible to melt brake pads against hot rotors. Of course, should a deer, pedestrian or Sasquatch run onto the road, feel free to mash the brake pedal. Safety first!
- Your stop-and-go session is now complete. Park the car and allow the brakes to fully cool for an hour. For best results, avoid pressing down on the brake pedal when parked
The rotors need to be fully cleaned from the current pad material - brake cleaner on a roloc pad on a drill is how I do it (it slings so do it outside with an old shirt on), then sand or file the surface of the brake pads (wear a respirator). The goal here is to get to a fresh layer of pad material that isn't already glazed - doens't take much - you want the shininess gone. Put it all back together and then bed them using the process in jfort's post and you should be good to go. Make sure to use either the OEM pad dampeners or an anti-squeal past on the BACKSIDE of the pad, not the friction surface. This will keep them nice and quiet so you don't get squeal when stopping.
If you need to bleed the ABS actuators and don't have a Durametric, you can just find a road with some loose dirt and do a few panic stops where you feel the pedal pulsing as that's the ABS pump working and will move the fluid through. A new home construction site is usually a good place where the trucks going in and out have left a bunch of dirt in the road.
Go to the StopTech website, which evidently is now APCAUTECH.COM. (https://www.apcautotech.com/resource...ry=Whitepapers) Head to RESOURCES and then WHITE PAPERS. At the bottom of the first page are 3 white paper articles that do a good job explaining the bed in procedure. Start with the BED-IN THEORY paper then read through the stock and performance papers. These are pretty good write ups and help you understand the bed-in process. I've followed these guidelines for years and have not had any problems. Good luck!
Poseur
Like they are suggesting, find a new shop. Better yet, do your brakes yourself if you have the time.
Fortunately for me, my brakes jobs are limited to bleeding the brake calipers and the clutch every two years. I'm still on factory pads at 115,000 miles. (PCCB)
Ok, so brought my car in to get the brakes done rotors, pads, and everything. So got the job done. Then about 1000 miles later my car starts shaking. Brought back into the independent, he says "You didn't break them in properly" and the rotors were warped and he needed to redo the whole job. He redid them under warranty but said that was the last time he'd do it and that to properly brake them in I needed to not slam on the brakes
Not trying to place blame on anyone here, but I've never heard of a break-in period for brakes, period. hahaha
