997.2 targa 4S winter tire question
Hi all.
I have winter tires and rims off a 987.1 Cayman and wondering if the tires would work on a 997.2.
They are winter tires (using stock tire size for summers)
Fronts: 225/40/18
Rears: 265/35/18
Would these be suitable for a 997.2 4S or should i
just sell them?
Thansk.
Fronts: 225/40/18
Rears: 265/35/18
just sell them?
Thansk.
Manual says 225x40 R18 Front
265x40R18 Rears
Offsets are 57 F 60 R
You could try them. When I first got my 2009 C2S, I used
18 winter wheels and tires from my previous 996 C4S for 2
winters b4 switching to 19. Kind of regret doing that.
265x40R18 Rears
Hi all.
Fronts: 225/40/18
Rears: 265/35/18
just sell them?
Thansk.
Fronts: 225/40/18
Rears: 265/35/18
just sell them?
Thansk.
Good luck.
Jeff
Look up the rolling circumference of those two tires from the manufacturer's website. If they're within 1% of each other you should be fine. Beyond that and you may cause issues with the 4wd system . There's no reason to run a 295 width rear snow tire - just makes it float on top of the snow when it's deep. The narrower tire will get down through the snow better and to the road surface for grip.
Make sure the load rating of the rear tires is high enough to support the load on the 911. Should be a label on your car that gives front / rear GVWR info. The rear tire needs to have a load index that equates to 1/2 that rear number or above.
Do you mean the rolling circumference difference between the front and rear? I looked up the rolling circumference between the stock fronts vs rears and its around 2.7% so unclear about the 1% rule creating an issue for the AWD system?
The difference between rolling circumference of the tires i'm looking to run is 0.8%...does this mean that I should be good?
Thanks for the help guys.
Jeff
Deep snow is relative. The car only has a few inches of clearance before the skid plates turn it from car to sled. But my experience has always been on thin snow that a narrower tire will cut down to asphalt a little better and a wider tire will float. The new thinking on winter tires is that they aim for a bit more snow adhesion to the tire and use the snow for traction. In that sense, the wider may have similar grip on ice, but I'd rather get down to asphalt if possible.
No. I run the pirelli sottozero in 265/40R18 rear 235/40R18 in front with the BBS SR in the correct offsets on my 997.2 C4S. I would think that your wheels should fit, but probably need a rear spacer to correct for the offset difference with the Cayman rear wheel.
thanks. So what I’m hearing is that the wheels plus tires may potentially work (with a spacer)? I checked
the tire height and I looks like the difference between front and rear is 0.2 inches. Will this create an issue with the AWD system?
The 235/40R18 265/40R18 is an approved combination for the 997.1 but the 997.2 only lists a 295/35R18 rear spec option which is 2.75mm smaller in radius in theory. The awd system is designed for offset whrel sizes so there has to be some tolerance. I have put about 4k on the car this winter and haven't seen any issues. However with a 225/40R18 front, you will be adding 4mm additional offset. I'm not really sure.
I'm running 235/35-19 and 295/30-19 Nokian Hakkapeliitta7s for two reasons: (i) availability and (ii) these are the registered sizes - if I wanted to run 18s I'd need to try and register the new tyre size (to stay legal) and the authorities might not agree. Especially since they can read tables.
Anyway, all this being said, I've not had any issues with snow, or even deepish soft snow. The constrant is the ride height, not the width of the tyres.
