How far did Your car go on the original brake discs..
Old 02-20-2019, 03:34 AM
Henrik964
Henrik964's Avatar
Default How far did Your car go on the original brake discs..
OK, Not a question for You with cheramic discs but the rest on steel discs. Mine is now on original and 144 000 km....
Old 02-20-2019, 06:00 AM
dgjks6
dgjks6's Avatar
10 years and almost 40K miles on the 997
My wife's macan I swapped out pads at 50K front and rear. Almost as 100k miles and going to do front and rear pads and rotors.
Old 02-20-2019, 08:11 AM
Uwon
Uwon's Avatar
I’m about to change the front rotors for the first time on my 997S at 109k Miles (174k km). Rears are still good. Mostly highway driving.
Johan
Old 02-20-2019, 09:22 AM
C4SDayton
C4SDayton's Avatar
Do Porsche owners have disks resurfaced when only changing worn pads, or change pads and go if disc thickness is fine?
Old 02-20-2019, 11:31 AM
Henrik964
Henrik964's Avatar
Johan
Johan, That is long! PDK or manual?
Old 02-20-2019, 01:16 PM
Iceter
Iceter's Avatar
My car is a daily driver. I accelerate and brake more aggressively than most drivers. My wear sensors tripped at about 45k miles. There was not a lot of meat left on the rotors to resurface so I replaced them.
Now I have almost 80k miles on the car and I suspect (from looking at the pad thickness) that I have maybe another 5k miles left in them The rotors are grooved and will need replacement again.
This is on an '09 C2 convertible.
Old 02-20-2019, 02:08 PM
dgjks6
dgjks6's Avatar
Long debate on whether it is possible. Some say yes and some say no. You can find arguments for both.
Old 02-20-2019, 02:10 PM
Gofishracing
Gofishracing's Avatar
until equal to measurement of brake pad back plate.
Old 02-20-2019, 03:39 PM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,418 Likes on 860 Posts
2009 C2S
My pads went at around 75K.... rotors were within limit but right at the border. I chose to change the rotors too.... I don;t know how much more I would have gotten from the rotors, but I changed them figuring I would't have to change anything again until 150K miles. Regarding resurfacing, yea, sure you can do that, but again, since they last so long anyway, I don;t know what you are buying.... change it out and you will have no issues for a long time.
Peace
Bruce in Philly
Old 02-20-2019, 03:57 PM
cosm3os
cosm3os's Avatar
88k and still going. Includes track work. Run em til they warp or crack.
Old 02-20-2019, 05:00 PM
max540i
max540i's Avatar
me too, 2009 997.2 C4S
Old 02-20-2019, 05:15 PM
GoldenGorilla
GoldenGorilla's Avatar
Fronts were replaced before I bought the car at 38k. I will probably do the rears this year around 55k. The rears show some cracks. Car started life in LA. Glad I don't have to drive in that traffic. I expect I should make it to at least 85k before I need to replace them again.
Old 02-20-2019, 05:34 PM
mujeriega
mujeriega's Avatar
09 C2 purchased with 61k miles. Front rotors & pads already replaced when I bought it... likely in the 50-60k range. Rears are still original now with 64k miles on it and look like they'll still last a bit longer (.5mm above min). Will just swap out rear rotors and pads at the same time sometime later this year or next.
Old 02-21-2019, 08:06 AM
Uwon
Uwon's Avatar
Manual. Reason for high mileage on the rotors is the extensive touring across North America that we have been fortunate to do over the years.
Old 02-21-2019, 09:05 AM
Matt(inMA)
Not in MA anymore
Matt(inMA)'s Avatar
'06 purchased new - ~75K I replaced the pads and rotors for the first time. Rears look fine
Matt
Quick Reply: How far did Your car go on the original brake discs..
