997.2 all red LED tails? - Rennlist - Porsche Discussion Forums
997 Forum
Old 02-11-2019, 01:24 AM
hexagone
Default 997.2 all red LED tails?
Has anyone done this? I've photoshopped it, but curious if anyone has done an all red film over their LED tails to get rid of the white/clear section.
hexagone is online now
Old 02-11-2019, 12:54 PM
F4nG
User
I did that w/ my old cayman and i was big fan of it.
I'm currently debating on doing that w/ my 997.2. However, it currently have the clear tail lights in.
F4nG is offline
Old 02-11-2019, 01:04 PM
bronz
bronz's Avatar
I was thinking about trying doing all reds on mine since one of the lights have hazing inside. I used to have all red tails on my audi B5 and loved the look.
bronz is offline
Old 02-11-2019, 01:09 PM
BillNye
User
Let's see this photoshop. I got curious about doing it in a similar manner to the recent thread where somebody painted just the interior black.
BillNye is offline
Old 02-11-2019, 01:26 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
As I'm sure you all know, Porsche offered a solid red tail light option for the 997.1 cars. I think it looked great on that car. I think doing something similar with the 997.2 cars would also look very good.
Dennis C is offline
Old 02-11-2019, 02:32 PM
Aeromat209
Suncoast makes a Red tail light film LaminnX that covers the white lens area for $59. Might be a way to try that look . I was thinking of getting the light tinted film to help protect my lenses as one of them had cracked and let 1/2 " of water in and messed up the Led's . Had to replace the whole lens unit .
Aeromat209 is offline
Old 02-11-2019, 02:35 PM
Dennis R. Cliff
User
I was under the impression that those clear LEDs in the middle of the 997.2 red tail lights were for illuminating what is behind the car when backing up at night. Am I wrong?
Dennis R. Cliff is offline
Old 02-11-2019, 02:52 PM
hexagone
I enjoyed the look of the LaminX film, but I found them to be a PITA to apply correctly. They give you about 2mm on each side of room for error, and if you handle the vinyl too many times around the edges then you have the risk of losing adhesion and it looks janky where it should roll over the plastic edge.
My second gripe is $60 for two precut sheets of vinyl... that's a lot.
The reason I'm interested in the red is because I can get a roll of red adhesive tail light vinyl for $10 and mess around on some less than perfect tails I have.
Old 02-11-2019, 03:10 PM
BillNye
User
You're partly right. Only the very center is reverse light.
Running light is the outer-most U-shaped lights at approx 50% brightness; brake light is the outermost U-shaped lights+the vertical bars nearest the decklid; rear fog is the left vertical bar nearest the decklid; turn signal is the middle ring of lights with the clear lens (which can be amber or red depending on your region, hence the clear); reverse light is the small center slit.
This is the thread I was thinking about. https://rennlist.com/forums/997-foru...7-2-tails.html you can see running lights, turn signal, and reverse light here.
BillNye is offline
Old 02-11-2019, 05:12 PM
bonehead
bonehead's Avatar
Sent you a PM
bonehead is online now
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
