Code 0301 & 1359
Location: Québec, Quebekistan, Magic Kingdom of Trudeauland
Code 0301 & 1359
Started my 997.2 today and engine started running rough (felt like misfires) and got the engine check light.
Got home and put it on the Durametric and I got the codes:
0301: Misfire detection Upper limit value exceeded
1359: Valve lift control, cylinder in small lift implausible signal
Sensor for the Variocam ? Ideas ?
Thanks.
Martin
Thanks.
Martin
Yep, sensor or the solenoid itself.
Ok thanks.
Even if I only get the code for 1 cylinder (cylinder 1) ?
I found instructions for the solenoid but not how to locate and remove the sensor.
Thanks.
Thanks.
If it was just the misfire code on cylinder 1, I'd say no, but since you actually got a valve lift error message, I'm thinking yes.
Before I physically check the sensors, I ran some more tests with the Durametric to look at actual values (cam shaft deviation, etc.) Could not see anything wrong there.
What I find a bit strange is that when I start the engine cold, I get the misfires and check engine when it is at 1200 rpm (high lift), then when it slows down to 800 rpm (low lift) there is no change and I still get the same misfires and check engine light.
Do you still think it could be the Variocam solenoid ?
Thanks.
Thanks Petza914.
Thanks.
Thanks.
It could certainly be the valve lift solenoid, but I would think you'd see codes for cylinders 1, 2, & 3 if that was it.
When was the last time you did plugs and / or coil packs. Maybe one of those on cylinder #1 is bad. If it has been 30,000 miles or more, I'd change the plugs and coil packs.
Since I need to get in there I will do the plugs first I think. If I had the misfire on cylinder #1 and nothing else, I would investigate the plug and coil. What is bothers me is the code on the low lift on cylinder #1 only.
Well the plugs are due. They were done at 48000 km in mid 2014 and I have now 77000 km. So it's been 4-1/2 years and I had plan to do them next summer. I use the car in winter here which is pretty tuff.
Finally changed the plugs (they were due anyways) and also the coil of cylinder #1. Everything is now fine. Was probably getting the cam code because of the misfire.
Thanks.
Aigle, great to hear that resolved your issue. If that one coil pack had gone bad, the others may not be far behind. I probably would have changed all of them while I was in there, but if you get a similar code again a bit from now, you'll know what the likely culprit is and can do the rest at that time. Another test would be to fill a spray bottie with water and while the car is running put it on a mist setting and spray around the backs of the coil packs, listening for any change in the way the engine is running. If the mist creates a stumble or misfire, the insulation on the backs of the coil packs is compromised and need to be changed.
