Looping door open sequence
This has happened maybe 3 times since I purchased the 997.1 back in November and again this morning. It’s my DD as long as weather permits (no snow or ice). This morning it happened again: I open the door to enter the DS and the window lowers as normal but immediately raises then lowers again and raises and repeats until I tap the window switch on the door. It also sounds as if the door locking mechanism is repeatedly engaging, could simply be the window mech making noise. Does this sound familiar to anybody? Any solutions? Apologies if this has been covered, I didn’t have great luck on the search. |
Originally Posted by HAAANK
(Post 15562452)
I have this same issue...Took it to my guy and they spent the better part of half a day messing with it, took the door apart, inspected the handle, etc. and we walked away shaking our heads. It is very annoying as it only started happening after I got window tint.
The interesting thing was that it seems to work appropriately after the engine is on. Battery tests fine also btw. |
Originally Posted by Vethen
(Post 15563302)
is it possible that the spring for the interior door handle is weak and the mechanism is lightly pressing on the micro switch, causing the window to drop and raise as it wiggles? |
How's the battery? These things are pretty picky about the battery health and as the battery ages all kinds of weird things start happening.
you might have bad stops on your window regulator which means a new motor regulator or perhaps the stop positions need to be relearned.. See if there is a window stop home position learning procedure, if not im guessing its your window motor regulator.
Originally Posted by Hella-Buggin'
(Post 15563925)
Thanks for the tip |
Originally Posted by aaks38
(Post 15564184)
I’ll look into that. Sounds promising. |
(Post 15562452)
I bet you the tint shop took the interior door panel off in order to be able to tuck the tint behind the window squeegee and when they put it back on, they didn't get the inside handle properly aligned with the door spear. If the took the panel all the way off where they removed the inside mechanism that the inside release handle attaches too, they didn't reinstall and adjust it properly.
If you get inside the car and close the door, then lightly fiddle with the inside door handle, does the window do its up and down dance. There's a pin molded into the back of that door handle that goes through a tiny little hole in the door spear and contacts a microswitch. If it's not contacting well, it thinks you're pulling the handle from the inside and drops the window. Because this started happening after the tint job, I'm betting that's your issue. |
