Aftermarket LED headlight bulbs
I hate the performance of my halogen headlights. Has anyone replaced their bulbs with aftermarket LEDs? Did it work well? Any issues?
Thanks, David 2008 GT3 Yellow |
Oops, misread as LED fogs.
I think the OP was asking about headlights.. not DRLs.
There was a thread here (or 6speed maybe..) a while ago that pointed to a particular LED kit and I think the conclusion was that it was an upgrade from halogen. Not so much when coming from Xenon lamps. I'm considering it myself.. The main gotcha is the special tool needed to remove the headlight assembly from the car. Another thing to consider is to polish the lens since it will be full of scratches and fading after years of use. That will also add to better lighting. |
you are going to lose the aiming and reflective charistics of the porsche headlite enclosure. otherwise start experimenting and tell us what you find
Bought LED headlights from DDM tuning. Absolutely no regrets.
I put LED headlights into new Spyder housings in my pickup and they are much better than the halogens that were in there before. The special headlight removal tool referenced is actually in your car's tool kit and the instructions on where and how to use it are in the owner's manual.
They're like $50 a pair on Amazon - If I had Halogens in my cars (I have Xenon) I'd give them a shot and see how they are. The Xenon lights are great and I wouldn't mess with replacing those, but since you have Halogens, I'd try it. I just bought some LED bulbs to replace the headlights in my 914 - better light and lower power consumption. Also replace the fog lights and aux lights in my 928 with LEDs to match the color of the HID headlight kit that's in that car. Big improvement. Here's a cool driving night shot of the 928 with them. https://cimg7.ibsrv.net/gimg/rennlis...ac9a88f4ab.jpg |
I haven’t done this in a Porsche, but I did this in one of my other cars. It’s a nice upgrade, but it has tradeoffs. The LEDs are much brighter. The main issue is that the beam pattern can be suboptimal when you install LED bulbs because of the way the light is dispersed compared to a halogen bulb. This could result in hot spots or dark spots. I’m not saying this will happen in all cases, but it’s possible. It happened to me. I still think the upgrade is worth it, but be aware that side effects are possible. |
Originally Posted by Dennis C
(Post 15555951)
Before you do anything watch this
Originally Posted by Sporty
(Post 15556351)
Are these simply replacing the halogen bulb with an LED bulb or is it more involved ?
Originally Posted by shyamvenky
(Post 15553618)
The main gotcha is the special tool needed to remove the headlight assembly from the car..
https://www.suncoastparts.com/product/99957107702.html |
"Plug and Play for most designs. One challenge is space in the headlight assembly. Ventilation for cooling is another potential issue. Neither of these issues mattered when I did this in my 2015 GMC truck."
Thanks Dennis. When I get some time i will attempt to pull out my light assembly and assess. I'd really like to do this conversion from my halogens, seems easier than HID conversion. Surprised to see that the LEDs need cooling as I thought they would be much cooler than other lighting, you know like the ones you use in your house light fixtures where you can touch the bulb and they are not hot. |
Originally Posted by Sporty;[url=tel:15557442
15557442[/url]]"Plug and Play for most designs. One challenge is space in the headlight assembly. Ventilation for cooling is another potential issue. Neither of these issues mattered when I did this in my 2015 GMC truck."
Thanks Dennis. When I get some time i will attempt to pull out my light assembly and assess. I'd really like to do this conversion from my halogens, seems easier than HID conversion. Surprised to see that the LEDs need cooling as I thought they would be much cooler than other lighting, you know like the ones you use in your house light fixtures where you can touch the bulb and they are not hot. Did you end up doing the upgrade? If yes, can you share the detail? Thanks |
(Post 15555951)
Yes I did this awhile back and they are a 100% improvement. No issues so far, was easy and inexpensive. Search this forum, I posted some pics and as well others have posted which ones to buy off Amazon
