p0304 Code - 997.2
I took my 911 in for emissions, and got the "monitors not ready" error... assumed it might have been if the shop has disconnected the battery during a recent springs install and wheel bearing replacement.
After driving it around for a couple of days to get the monitors ready, I got a check engine light. After restarting the car, I checked it with the OBD reader and saw the P0304 code. Any thoughts on what this means? It may be my imagination, but I think the car was also running a bit rough around the time this happened. thanks! https://cimg8.ibsrv.net/gimg/rennlis...451ac07ea6.png |
If it's any help, looks like the monitor that was not ready earlier was the EGR/VVT one... (the catalyst had become "ready" soon after I took this screen shot)
https://cimg9.ibsrv.net/gimg/rennlis...173fe28530.jpg |
Even though this is on a .2 with the updated coil packs, I’d start my suggesting to look at your coil packs and see if any are looking cracked. Was the car wet recently? |
How many miles on the car and how long since plugs and coil packs have been replaced? If more than 30,000 miles that's probably what you need and you might as well do all of them as it will just be a matter of time before the others go bad and do the same thing once one fails. The other thing that can cause a misfire in only one cylinder is low compression, but that's unlikely and it's probably just the plug or coil pack.
Thanks- car is a 2010 and has about 75k miles, plugs are about a year old. I don't think the coil packs have ever been changed.
If the battery was disconnected for a while, then the computer has to reset itself.... someone here knows the official words for this process.... something about readiness or whatever..... It takes some elongated driving time before the car knows itself.
Check out #28 here... this is for the 996 but I am sure the issue is the same for all of our cars.... process may be different... do some more research: https://rennlist.com/forums/996-foru...t-ready-2.html Peace Bruce in Philly |
Update on this- looks like it was indeed a cracked coil. I went ahead and had all of them changed as they were reported to be due, drove around for awhile and saw no pending codes. And passed my past-due emissions :)
Originally Posted by adnan76
(Post 15558345)
I was just at the P dealer yesterday and the SA suggested replacing the coil packs when you do the plugs on a 997.2. I know the 997.1 have a propensity to crack but didn’t think it was an issue on the .2. Mine looked fine when I replaced my plugs so I left them. I figure I will do them when I get a misfire code or are guys replacing them preventatively at a certain time or mileage? |
Originally Posted by docdrs
(Post 15560690)
(Post 15560690)
I was just at the P dealer yesterday and the SA suggested replacing the coil packs when you do the plugs on a 997.2. I know the 997.1 have a propensity to crack but didn’t think it was an issue on the .2. Mine looked fine when I replaced my plugs so I left them. I figure I will do them when I get a misfire code or are guys replacing them preventatively at a certain time or mileage? Peace Bruce in Philly |
Originally Posted by Petza914
(Post 15560744)
The new style coil packs with the thicker insulator back section (require longer screws when upgrading from the old 997.1 style) are supposed to last longer before cracking and the reason for the update. I'd leave them alone until you get misfires. They'll show up first when driving in the rain.
