'09 997.2 Codes 171/174
Above car with ~10.8k miles (yes, I know) Bought from dealer in Nov. '18.
Fully inspected. R/R'ed many items, mostly calendar.
While local driving this a.m., CEL comes on. Stopped by the a local non-dealer Porsche shop and a quick check showed both P171 & P174.
Engine idles smooth, accelerates fine. Have not got it up to speed though.
Checked fuel cap - open & closed tight. Still throws the CEL.
About to head off on a 4 day trip tomorrow. Shop can't get to it today.
Any thoughts?
Any thoughts?
Might be some starting points here:
P0171 Oxygen Sensing Adaptation, Idle Range, Bank 1 – Above Limit
P0174 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Above Limit
Possible fault cause
- Incorrect signal from MAF sensor
- Intake air system leaking
- Fuel pressure too low
- Volume supply of fuel pump too low
- Fuel injectors fouled
- PCV valve leaks
- Cap of oil filler neck not closed correctly or seal is damaged
- PCV valve leaks
"Cap of oil filler neck not closed correctly or seal is damaged"
I'm going to go with that. Put 1/2 qt. in last night.
Previously owned a Cayman S, so was surprised to see the "tube extension."
Thought it was tightened but I guess not. Unscrewed/rescrewed the cap twice, seems to be tight. Got the last little "dull click."
Give the man a cigar. Thank you "Psycopoodle."
Now, how do clear the CEL? Or just drive?
I had the same issue when I bought my car and drove it back. I added a quart of oil and didn't seal the cap. The car started idling rough and at 1500 rpm, threw the P0171 and P0174 codes. The next morning I resealed the cap and the following day the CEL went away.
2009 C2S 130K miles
Yea, I threw codes ..... screwed on the oil cap crooked... how the heck you do that is beyond me but I did.
Peace
Bruce in Philly
Peace
Bruce in Philly
