QUICK JACK BL-5000SLX 5,000-LB fit?
Old 12-18-2018, 12:52 AM
fat_louis
fat_louis's Avatar
Default QUICK JACK BL-5000SLX 5,000-LB fit?
Hi everyone:
Will a quick jack portable car lift fit underneath a 997?
It seems like it would be a tight fit.
The rails on the lift are 70" long and it seems like that would be a very tight fit between the tires.
Does anyone have a quick jack?
I would get the 3500# rated one which has shorter rails, but I have other cars to work on that are heavier.
thanks
fat louis
Old 12-18-2018, 01:01 AM
der Geist
der Geist's Avatar
I have the 3500 pound model and it fits fine. I am pretty sure if you call them or Pelican Parts they will tell you which model will be best for your needs. Both of those i mentioned have great customer support.
Old 12-18-2018, 03:28 AM
ADias
ADias's Avatar
The 5000 SLX lifts a 997. It needs to be positioned just right, though.
Old 12-18-2018, 06:15 AM
Arctic997
Arctic997's Avatar
I purchased the 5000SLX model QuickJacks because I didn't want to be limited by the 3500# model.
They fit perfectly under my 997 with H&R lowering springs using the short rubber blocks (included with QJ's), and the box they came in actually has a 997 on the box.
If anyone is interested, I called Bend-Pak before purchase and got confirmation that the Hydraulic cylinders as well as the pump are the same as the 7000# model, it's just the framework that is different. Then I found a video of the manufacturer lifting and supporting 26000#'s on the 5000# model using an upgraded pump. So I'm fairly confident the 5000# SLX is capable of lifting and supporting any vehicle I currently, or will in the future, own.
One of the best tools I've ever purchased. Love 'em.
Old 12-18-2018, 08:11 AM
linderpat
linderpat's Avatar
Received 2,248 Likes on 1,253 Posts
Following. I saw Costco recently had them on sale for $999.
Old 12-18-2018, 08:47 AM
swingwing
swingwing's Avatar
My BL-5000SLX fits jes' fine:
QuickJack BL5000SLX on first raise position.
Old 12-18-2018, 08:55 AM
swingwing
swingwing's Avatar
I also use these pads that work great.
https://www.amazon.com/Universal-Porsche-Polyurethane-Protector-TMB/dp/B01LZYGI63/ref=sr_1_3?ie=UTF8&qid=1545137606&sr=8-3&keywords=porsche%2Bjack%2Bpad&th=1 https://www.amazon.com/Universal-Porsche-Polyurethane-Protector-TMB/dp/B01LZYGI63/ref=sr_1_3?ie=UTF8&qid=1545137606&sr=8-3&keywords=porsche%2Bjack%2Bpad&th=1
Old 12-18-2018, 09:42 AM
semicycler
semicycler's Avatar
The one I saw from the manufacturer was holding 16000#'s on an unmodified BL-5000SLX but not lifting it. They were addressing safety concerns about crawling under the car. I'm sure there are other videos out there.
Here's the link:
Old 12-18-2018, 05:51 PM
AMF997S
AMF997S's Avatar
I have the 7000 SLX and it fits my 997 but is tight - wish I'd bought the 5000 SLX becasue the extra weight of the 7000 is a pain to move around. Thought I needed the extra capacity to lift my wife's ML 350 Benz.
Old 12-18-2018, 07:58 PM
markmark26
markmark26's Avatar
I have 7000 slx and it fits just right my 997 turbo
Old 12-19-2018, 03:45 PM
Steve 911
Steve 911's Avatar
Love my quick jack. One of the best uses of $1k available when it comes to garage stuff
Old 12-19-2018, 03:49 PM
Appraiser
Appraiser's Avatar
To those with the QJ - has anyone removed their transmission with it? Is there enough clearance to get out the transmission and/or engine?
Thanks,
Colin
Old 01-10-2019, 09:27 PM
Arctic997
Arctic997's Avatar
Thanks,
Colin
Thinking I'm going to need to do a clutch at some point, I bought wheel dollies to temporarily support the car. i.e.lift enough to set on dollies (any blocks to support car would work), add blocks, lift again. I think required clearance to drop engine and/or trans is 20". The included blocks, and lifting in 2 steps yields 21" at the lift-points.
Although I could be wrong about the required height, might be only 18", could be 24", too lazy to confirm. I'd confirm before I started the job, but nearly irrelevant. I would just use larger blocks if I needed more height.
This pic is sitting on both rubber blocks, included with 5000SLX QJ's, and lift-pucks (manufactured and sold by RL member SmokinGTS) clearance is 21" at the lift-points.
Old 01-10-2019, 09:51 PM
Christian Stark
Christian Stark's Avatar
I have been eyeballing this at Costco too. QJ sells pads for suv lifts, and using these get a 997.2 well over 2 feet off the ground. It is a 2 step lift process where you lift and then put wheel cradles under your he wheels. Then lower the QJ and place in the SUV pads, and lift again.
http://forums.pelicanparts.com/porsc...iple-911s.html
Old 01-10-2019, 09:54 PM
avonted
avonted's Avatar
I would HIGHLY recommend buying direct from QuickJack (which is BendPak). Pelican sold me the wrong one and then gave me a real run-around to make a change. I actually reached out to BendPak and they took care of me. The 5000SLX is what you want for a 997. This is a fantastic product.
Quick Reply: QUICK JACK BL-5000SLX 5,000-LB fit?
