Replacing sticky knobs on my PCM?
Replacing sticky ***** on my PCM?
Over the past decade the two rotary buttons on my PCM system have a rubber rim that has degraded into a sticky mess. Where can I get replacement buttons? Thank you!
I took mine off, sprayed them with PlastiDip in black. No more stickiness. Feels just like new. Couple dollars for a can of PlastiDip.
997.1 the ***** pull off. 997.2, they are anchored with a screw. Be careful if you have a 997.2
If a 997.2, and you want to use GooGone or alchohol, do this without taking the ***** off and be careful to not get the stuff on other plastic parts.... wet your cloth. Why not take the ***** off? Because you will crack the the little caps. You must pry the caps off to get at the tiny torx screws... you will crack the caps. I have a 997.2 and just purchased replacement *****... probably could of just cleaned them with solvent... but I didn't.
https://rennlist.com/forums/997-foru...m-*****-2.html
Peace
Bruce in Philly
Peace
Bruce in Philly
PCM buttons - https://www.suncoastparts.com/produc...M9971KNOB.html
AC switches - https://www.macarbon.com/sticky-refinishing
Had mine replaced by the dealer a couple years ago. Not as cheap as these:
https://www.ebay.com/itm/GENUINE-POR...53.m1438.l2649
