A little OT but does involve my car: Toronto to California road trip
I will be leaving mid-Jan to drive from Toronto to Phoenix and then Palm Springs. Will be in CA for a couple of months then heading back to Toronto for early to mid-April.
I will not be in a rush and plan to avoid interstates. Hence i am looking for suggestions for routes or roads that i should try and make. I am thinking i will stay more east coast down the Appalachians till its a bit warmer, then across. Am planning to leave around Jan 21 to get to Phoenix around the 29th, spend a couple of days there, then to PS for Feb 1st.
I have AWD and full snows but obviously some routes will be weather dependent. If I run in to really bad weather then i will hunker down in a Motel 6.
Given the spread of people on here thought i would ask for suggestions.
Many thanks!
Many thanks!
Sorry, I can’t give you any route advice. But if you find yourself west of San Bernadino and headed east back to PS, try to avoid the 210E at the interchange with 10E. It used to be a 2 lane merge on to 10E but CalTrans decided to merge 210E to one lane before 10E so traffic gets really backed up (this is as of late October). Also on 10E at the interchange the lanes split with the left lane separated by a jersey barrier from the right lanes so it gets messy here as well for about four miles (also circa late October).
East of Phoenix, you'll probably want to hit the route from Clifton through Alpine and then maybe over to Show Low and down to Globe. I've been meaning to make it over specifically for the Clifton to Alpine drive but that's a bit much to do as a round trip from Phoenix in a day.
Be advised that there was a pretty big fire in the Idyllwild area this fall and there have been some serious concerns about mudslides throughout the recent CA burn areas.
As for routes.. All of this is high desert or alpine mountain terrain and can have extreme and sudden changes in weather in winter.
Most of the fun stuff in CO where I call home is going to be something you'll need to monitor weather very closely. But if the weather is cooperating, taking the southern route across CO (US 160) or norther NM (I-25/US-550/US-64) can offer some cool roads and scenery. I would highly recommend that you find a way through the Rockies and then get onto UT-24 from Hanksville through Capital Reef and then down the UT-12 through Escalante. The area around Boulder, UT is a high mountain area and can catch alot of snow at times when other nearby areas are dry, so monitor weather there. Route 12 near Upper Calf Creek falls is in my opinion, one of the coolest roads anywhere and I can't wait to go drive it in my 997.2. Head down UT-12 past Bryce Canyon through Kodachrome Basin and then US-89 to the UT-9 to Virgin/Hurricane. Beyond that point, I can't offer any further guidance.
This is all passable in winter and spring and typically dry with good weather, but it is remote and help is not just around the corner.
yes and yes. See my post here: https://rennlist.com/forums/racing-a...l#post15271120
If you come through Virginia, please do not speed. The cops here are ridiculous. 10 over is a wreckless driving and mandatory court. Not fun 😒.
Otherwise there are some some beautiful sights down the blue ridge parkway. But it’s slow going.
Casey
Casey
A little inspiration for UT 12 near Calf Creek, though this doesn't show how beautiful the view to the sides is. It does show why this section of asphalt is the coolest.
From https://www.brycecanyoncountry.com/w...enic-byway-12/
Cheers
