PDK Transmission Emergency Run
Anyone had this error more recently? There are quite a few posts from a few years ago.
Was driving the 911 today for a fun drive since it broke 40 degrees Wasn't even driving spiritedly (I was in sport at the time) and the warning came up in white text while I was on the way back home. Car drove and shifted fine but wouldnt switch to sport/sport plus. Got home and restarted, warning went away and drove around the block, no problem.
The other threads mention voltage problems. The car has been parked for 3 weeks but has been hooked up to a CTEK maintainer the whole time. Battery was the one in the car when I bought it, but I believe it has a 2018 date code.
It's going back down below freezing with snow so the 911 is going back to being parked, or else I would probably take it by the dealer this week. Should I buy a bluetooth OBD reader and see if any codes pop up?
I've seen it a few times on my 987.2 Cayman S. In my case it was related to misfires (caused by ignition coil or spark plugs). Car would register a misfire and part of it going into limp mode was showing transmission emergency run. Since I changed the plugs and coils its been fine. But as I understand it there are a number of precipitating factors that can cause it. When I pulled the codes with an OBD II reader all I had was info about misfires. Its worth having an OBDII reader around even if it doesn't answer the root cause in this case.
vokain (03-28-2022)
Just another data point for you to consider—my ‘09 C2 went into transmission limp mode a couple times with my car after I’d had it a few months. In my case, i would shift into Drive, but the car wouldn’t move. It would always clear on re-start and was very sporadic. I had other electrical gremlins occurring at the same time so I replaced my battery and they all went away. I haven’t seen the emergency run message since.
Robocop305 (07-25-2021)
Also had the same warning about 6 months ago on my current GTS the day after the 60,000 mile PDK service was done. Car went into limp mode and again, flatbed to the dealer. This time they cleared the fault but couldn't quiet explain what went wrong.
Not sure if this applies to "more recently" but about 3 years ago I got the same warning on the -09 C4S. Shut it down and that cleared it. Got the same warning about a month later. Same process. Shut it down and the warning went away. Then same thing a third time and that time it wouldn't clear no matter how many restarts and the car wouldn't move. So flatbed to the dealer who advised me that the PDK had to be replaced.
I say the battery or the low temperature.
Sorry about that. Wasn't my intention. Failures that require replacement are supposedly very rare. It's a great transmission but all the electronics involved seems to be the weak link if there is one since the dealers aren't allowed to do much if any actual repair work on them. That's my only misgiving about the PDK. Obscure electronics over which you have no control can fail and require full replacement of the whole transmission no matter how gently you treat the car and no matter how promptly you comply with the maintenance schedule. As I said in an earlier post, the PDK in my current GTS went into limp mode (which means the car can't be driven) the day after I had the the 60K mile PDK service done at my dealership. "Electronic gremlin" was the best explanation they could come up with.
Three years ago, I got the Red Transmission Emergency Run error on my '09 C4S. I was able to restart the engine and drive home but took it to the dealer to check it out. Their fix was to reflash the PDK software. Fortunately, I was under CPO warranty, so there was no charge.
Sorry about that. Wasn't my intention. Failures that require replacement are supposedly very rare. It's a great transmission but all the electronicsso involved seems to be the weak link if there is one since the dealers aren't allowed to do much if any actual repair work on them. That's my only misgiving about the PDK. Obscure electronics over which you have no control can fail and require full replacement of the whole transmission no matter how gently you treat the car and no matter how promptly you comply with the maintenance schedule. As I said in an earlier post, the PDK in my current GTS went into limp mode (which means the car can't be driven) the day after I had the the 60K mile PDK service done at my dealership. "Electronic gremlin" was the best explanation they could come up with.
so what happened with the car I’m having same issue... the car needed to have a transmission replaced and just got rid of it ?
Observation for what it's worth. At the time of replacement there was not one single 997 PDK unit available in the entire US. At least not at any Porsche dealerships or their warehouses so my replacement unit was flown in from Germany. A $250 deductible to Fidelity and a two year warranty on the replacement unit sums it up.
