Engine rebuild - rod bolt failure
Old 10-26-2018, 04:17 AM
racer5j
racer5j's Avatar
Default Engine rebuild - rod bolt failure
Not trying to spark fear but just wanna add another data point and share my story. I have a 2008 C2S with 78k miles. I bought it last November with 76k miles. Long story short, I blew the motor at an autox last weekend. Initially, I thought I spun a bearing due to oil starvation because I run wide sticky tires and the car generates a lot of grip. However, a motor teardown has revealed that a rod bolt on my #6 cylinder backed it's way out and chewed up the motor. A quick google search revealed that this is a known issue on high mileage M97s.
https://www.pelicanparts.com/techart...a_Problems.htm
Vision Motorsports is performing the rebuild and, per usual, they are great to work with. The block, crank and cradle have been sent out for inspection to determine if they're salvageable. If so, we'll likely move forward with building a 4.2L motor.
Like most who bought a higher mileage 997.1, I expected (but was hoping not) to rebuild the motor at some point. I just didn't expect it to be so soon. Still, I'm excited for the journey that lies ahead and can't wait to dive into the details of building a new motor.
Andrew
Old 10-26-2018, 11:44 AM
semicycler
semicycler's Avatar
4.2L is impressive. Would love to see a build thread if you go that route.
Old 10-26-2018, 02:06 PM
voiceprint1
voiceprint1's Avatar
does this problem extend to 997.2 DFI engine as well?
Old 10-26-2018, 02:09 PM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,417 Likes on 859 Posts
I have not read of a single failure like this for the DFI engine.
Peace
Bruce in Philly
Old 10-26-2018, 08:22 PM
Iceter
Iceter's Avatar
I would think a loosening rod bolt would get noisy as the big end of the rod got loose around the crank journal. What were the symptoms?
Old 10-26-2018, 10:32 PM
morefun
morefun's Avatar
Sorry to about about the unexpected expense. Just curious, any over rev or extensive track use history? Ive heard M97 rod bolts are prone to stretching when spun too fast and/or too long. Was a concern with my M97 Cayman that I sold with 63,000 miles and 65 track days in advanced run groups.
Old 10-27-2018, 03:18 AM
racer5j
racer5j's Avatar
I've been replaying the final moments in my head over and over for the past 2 weeks. However, my local autox courses are generally pretty fast so I usually hit the soft rev limiter once or twice per lap. This particular course was quite fast and I intended trying out 3rd gear once the track rubbered in but I never got that chance.
On my second to last run before blowing up, I crossed the finish line after just hitting the rev limiter. As I was slowing down in the runoff area, I let in the clutch and when I was turning to get out of the course, I realized that I had no power assist. That's when I realized that the motor had shut down prematurely. I pulled off and restarted the car and it seemed to be running fine. In retrospect, perhaps there might have been slightly more clatter which I assumed was just lifter noise but there was definitely no obvious signs of something wrong. I sat in the staging until I deemed that the car was fine and then staged for my next run.
On my last run, the car seemed to run normally. However, when exiting a 180 degree corner just after a fast section of the course, I noticed the car was down on power and I heard a wheezing sound. I immediately shut it down and coasted to a stop. I restarted the car and there was a loud knocking sound so I shut it down again. At this point, it was pretty obvious that the rod had fully separated from the crank.
The previous owners did not track the car. I've only autoxed the car maybe 6 times since I've owned the car so the car doesn't have a long track history. Still, there are people in my region who have well over 100+k miles and heavily track and autox their M96 and M97 cars.
I was at Vision today and they said that there were some recent range 2 over revs, which would be consistent with my hitting of the limiter during my runs. Vision said that rod bolts may stretch and come loose when an engine is "back-holed", which is when a downshift is missed and the motor is instantly spun up due to being in the lower gear but perhaps not fast enough to overrev the motor. I've never back-holed the car and usually match revs on my downshifts but perhaps I did a poor job one too many times. Vision also said that as a precaution they usually recommend ARP rod bolts when rebuilding a motor regardless of whether using stock rods or Carillos.
Photos of the damage are forthcoming.
Old 10-27-2018, 04:08 AM
racer5j
racer5j's Avatar
Crank appears to be usable but will be inspected for cracks next week.
Closeup of crank damage
#6 piston and rod
Cylinder chunks
IMS is clearly not salveagable. IMSB (big bearing) was still in good shape tho.
Cracked cradle not salvageable
Closeup of the crack near the oiling hole
Thankfully no cylinder head damage
Old 11-03-2018, 03:12 AM
racer5j
racer5j's Avatar
Just a quick update. Thankfully, my block and crank are repairable so we should be able to proceed with a 4.2L build while staying within my budget. Shutting the motor down quickly saved me.
We haven't finalized the details for the build but will on Monday. I've been following a few other threads like Project Dora and Going Under the Knife for ideas on what to check/replace while the motor is out. Off the top of my head, I can only think of a handful of things:
  1. AOS
  2. plastic waterpump
  3. LNE IMS
  4. coolant tank
  5. starter cable
  6. oil pressure sensor
Please feel free to share other ideas. Thanks.
Old 11-03-2018, 09:15 AM
Petza914
Petza914's Avatar
Received 6,166 Likes on 3,930 Posts
New chain tensioners and cam position sensors
Old 11-03-2018, 01:52 PM
Hella-Buggin'
Hella-Buggin''s Avatar
Go with the Motorsports AOS
Old 11-03-2018, 04:24 PM
Coopduc
Coopduc's Avatar
Racer- are you sure the crank can be saved? These main and con rod journals look bad, and there is indication of excessive heat in the area. Hope I’m wrong, and like to hear the shop’s rationale and/or plan to rework it. It may help others save their engines.
Old 11-03-2018, 06:20 PM
JustinCase
JustinCase's Avatar
  1. AOS
  3. LNE IMS
  4. coolant tank
  5. starter cable
Based on what I did in my rebuild, everything you have above plus low temperature thermostat, LNE's billet aluminum paddle for the chain tensioner (and replacement guides), ARP carrier through bolts and head stud kit, and coated main and rod bearings. I assume you are getting the liners plated with Nickel Silicon Carbide ("Nickies") to replace factory Lokasil. I went with the pressure-fed oil plain bearing "IMS Solution" to avoid using a ball or roller bearing altogether as my extravagant upgrade, but if I could have afforded more, I would have upgraded the rods, too. I did take the opportunity to replace my clutch since the engine and transmission were already apart and it only really cost me the price of the parts (original clutch was at about 50%, so it was kind of a "push").
Old 11-03-2018, 07:25 PM
racer5j
racer5j's Avatar
Coopduc- The crank has been confirmed to be repairable. Initially, Vision didn't think the damage was too bad. Mainly, they were concerned with whether the crank was cracked. I am going with their "sport" crank which is knife edged so perhaps some of the damage gets machined off in the process. Also, according to some websites, it seems that even significant damage (excepts cracks) can be repaired without compromising strength. The repair process involves welding on material and then machining the excess off. I'll ask about the heat discoloration on the journals. I used to run 5W-40 with high zinc content but will switch to 10w-60 in the new motor.
Thanks everyone for the input. Much appreciated. I have a feeling that I won't be able to replace/upgrade all these items but will do my best to cover as many of them as possible. Please keep it coming.
Old 11-04-2018, 02:12 PM
street rod
street rod's Avatar
What is the rationale for switching to 10w-60?
Quick Reply: Engine rebuild - rod bolt failure
