Going under the knife
Car goes into my favorite indy next week for the following:
- IMS upgrade (LN latest iteration)
- RMS - fix a drip
- clutch - why not, 78K on the car
- water pump, thermostat - leaking badly, and prompted the service now rather than over the winter when I can't drive it anyway.
- AOS replacement
- coolant expansion tank replacement
- a/c condenser - existing one recently fried
Maybe engine mounts and transmission fluid?
From your signature it's a 2005? Do the alternator to battery wire harness while the AOS is being done. Low temp thermostat - "experts" believe this helps prevent bore scoring. Perhaps 3rd radiator while you are in there.
I'm doing same thing October 30th on my 2007 C4S - Car has 76K miles ---> car going to Aker's Porsche here in Seattle for:
-water pump & thermostat
-RMS & Clutch - PPI showed RMS no drips but weepage so doing clutch too - why not?
-Brake flush - Front brake rotors/pads/sensors
Linderpat since our cars are going under knife, I'll like church candles for both of us.
One thing I've noticed not many people replace is the trans mount. Since they are taking the trans off, they can press a new mount in there and will help clean up shifts.
Keep em coming folks. Another one from another thread is the alternator harness. What's the issue with that?
^^^linderpat you thinking of changing out flywheel?? With 75K on clutch, I'm probably replacing mine but I'd love to save $800
My indy doesn't like to send them out to machine shop for re-facing - He feels if they have enough crap on them better to start fresh so they sit nice and tight with no play of any kind and cost to machine is about $275 - I have to agree but $800 is a lot of sushi
**RennPart(Racing parts co.) is a great source for OEM parts - Outfit is in Florida - I've dealt with owner Aaron
Here are prices I paid including shipping all OEM:
Sacks Clutch Kit - $495
RMS - $31
Water Pump and Seal - $249
Flywheel - $733
RMS - $31
Flywheel - $733
RMS - $31
Flywheel - $733
RMS - $31
Flywheel - $733
RMS - $31
Flywheel - $733
RMS - $31
Flywheel - $733
Not sure about the fly wheel. I'll let my indy make that call.
I'll have to check my service history, but I think coils/plugs were done recently, before I bought the car. Otherwise, yes, that's the time to do those too. I have coolant tank already on the list, and brake flush is my job - do it multiple times due to track events. I also do my own oil changes (in fact most maintenance, except for big stuff). I am guessing that the shop will need to do an oil change because they are replacing the RMS.
Basic Sponsor
RMS - $31
Flywheel - $733
RMS - $31
Flywheel - $733
We are actually in North Carolina, no hard feelings for those Florida guys!
linderpat - is your 928 going under the knife OR the 997? I was assuming 997 didn;t realize you had the 928 too
