Eibach Springs On Older Shocks
#32
Lemfoerder is OEM for many auto manufacturers. I would have no hesitation installing those on my car.
(I personally avoid Uro Parts and Meyle).
You should also get the associated bearing and support ring and all that jazz.
#33
Update FYI - got my car back and drove it about 40 miles. The car's stance is much 'sexier' and the ride and handling is more composed and tighter and steering sharper - definitely an improvement all around. I had the top strut mounts and bump stops replaced as well - total with labor, alignment and tax was almost exactly $2K. My only nit is that my steering wheel is not dead center, off by 5-10 MM but is an easy adjustment I assume . Also had the original plugs and coil packs replaced (after 30k miles and 13 years )- old plugs and coils looked fine but i do notice better response in the 2000- 4000 rpm range as it previously felt a bit 'dead' in that area, about $800 for that, also had front brakes (with new ceramic pads) and rotors replaced another $500 or so ,plus my frunk struts were weak and had them replaced another $150ish. All in, a tick over $3,500, money well spent as it needed all these things. and feels like a new /different/better car . Oh, as far as the drop- on the rears, previously was a comfortable 3 fingers,(index, ring and middle) now a very tight barely index and middle. I may move my 15mm spacers to the front and replace the back with 20mm if thats ok to do ( i have base 18 by 10 wheels I believe in the back). Sorry no pics right now, but there are plenty on the interweb of others.
