PORSCHE 997 C2S RUNNING ROUGH
did you do the pump change?
The pump is in rear bottom drivers side of engine next to the water pump. Replacing it requires coolant lines (entire coolant flush is needed $$) to be removed so replace water pump while you are doing it.
