305 Rear "Plus" Size Tires but what about "Plus" Size Fronts?
So I know that 305/30/ R19 is a common "upgrade" for many owners, but it seems that not many owners widen the fronts, and keep the stock 235 size fronts.
I went to 305's in the rear, and 245's in the front, with no ill effects that I can tell.
I am currently running 305/30/19 rears and 245/35/19 fronts, which makes for a closer match of front/rear overall diameter.
Is there something that I am missing?
Thanks all.
Thanks all.
Running:
235/35/19 - 19x9
325/30/19 - 19x12
Only thing I notice is more grip, harder to break the rear loose. Car feels a bit more sure footed and planted. I made the move shortly after getting the car a couple years ago so I can't rightly say about noticed difference with turn in or braking distance.
235/35/19 - 19x9
325/30/19 - 19x12
Running:
235/35/19 - 19x9
325/30/19 - 19x12
235/35/19 - 19x9
325/30/19 - 19x12
I have the wider Porsche 8.5j fronts and 11.5j rear. 235/305 as it came from Porsche. I don’t feel the need for wider rear tires as I feel they offer plenty of grip and not very easy to break loose unless your really try hard. I do think going 245 up front will help with better grip, steering feel and braking.
anyone who went 245 up front noticed any significant change?
also helps if one is running a sticky tyre like Michelin 4s or cup2 in stock sizes before trying wider types. Maybe that’s all you need.
I am going to be on 245s in front but it won't be an apples to apples as I am also going 19 to 20 and to a different tire (Invo) after Pete's input. Lastly, I am not expert enough or push the car enough to make any comments unless the differences are striking.
I think on my next set I'm going to run a 245/35-19 on my 8.5" wide fronts and a 325/30-19 on my 12" rears. Both are available in the Nitto Invo which is my tire of choice.
This car will most likely never see the track anyway so I doubt I will ever notice any ill effects. One positive for me was the additional rim protection from the 245's.
Also, I must add that I am not a fan of the stretched tire look; I like the looks of a tire that appears to be just a bit wider than the rim. Not excessively wider, but just a bit.
I am running 8.5" front 11.5" rear rims.
Of course, every tire mfg is going to be a little bit different in size, so that matters too. I am currently running the General G-Max RS all around and are happy with them as far as daily driving goes.
One thing I will say as someone who just got new PS4S a few months back was 305s seem like no issue on the rear of my C2S Lobster FORKS. FORKS!
However, I used to mount tires and I was watching my friend mount the 235s on the front and they seemed wide for the stock rim. What I mean by this is a 245 would be pushing it to me but if other people have done it, I might be wrong. I wanted to go 245 in front but I didn't find other people running that size on the 997.1 C2S Lobster FORKS.
My fantasy is to get wheels that will let me run 255s or so in front and maybe even like 325 rears.
I will just leave my favorite picture here (sadly of someone else's car but someone from rennlist!)
https://rennlist.com/forums/997-gt2-...-hre-r101.html
Specs:
18x9.5 18lbs. 265/35/18
18x12 19lbs. 335/30/18
I would definitely run 18s to stuff this much rubber into the wheel wells of a NB 997.
Specs:
Beware that not all manufacturers' tires measure out the same way in reality. A 235 from company A might turn out to be within a few mm of a 245 from company B. With so much variability between brands/models/compounds/quality, I would choose your tire make/model first (whatever suits your usage & budget) and go with whichever correct size they offer for your wheels. It would be false economy to install a set of 4 lesser tires just because the front fitment says 245 on the sidewall. That's not a guarantee such tire will actually put a larger/better/grippier contact patch on the road than a 235 from a superior manufacturer. Much more significant are the other characteristics of the tire (materials, weight, reliability, feedback, predictability, wet traction, etc, etc, etc), all of which should outweigh a "claimed" 10mm difference in the width.
The 305's are not "a plus size over stock". I believe all C4 and C4S's came with 305's as stock
I understand the only advantage to 245 vs 235 on the front is to try and dial out a bit of the understeer built in to the car with the factory set up. If you are not pushing your car i to understeer situations then you are never going to feel the difference in sizes
