DME relay
DME relay
I have a 997.2 and lately, intermittently, it stalls. The coils and spark plugs were replaced. I like to check the DME relay to see if it needs to be replaced. Can anyone tell me where is it located at on the 997.2 ?
Stalls at idle, or when driving, when warm or cold, clutch in or out (or PDK), etc
Better questions get better answers...
When I took out the subwoofer, I believe I saw the ECU bolted under the tray, similar to this photo from SW. Let me double check as I will remove the subwoofer again and check if there are relays near the ECU.
