Goal when spacing wheels out
I really love the look of your car! I wish I had gone lighter . Atlas is unique but subdued. On the subject, I little a little more sticking out, so I vote at least 10mm up front and at least 15 rear. I just bought 15 for front and 18 for rear, but have not installed yet.
RSS Wheel Spacer Kits | Back in Stock!
Increase track width, fine tune handling and enhance the visual appeal of your Porsche with RSS Wheel Spacer Kits.
Wheel spacers are considered by many as “the gateway mod” of vehicle customizing and tuning due to the instant results and ease of installation.
RSS Wheel Spacer Kits are available in 5mm, 7mm, 15mm and 18mm Hub Centric Designs.
Suggested Fitments: 996 - C2 / C4 / Turbo / GT2 / GT3. 5mm or 7mm Front Axle combined with 7mm or 15mm Rear Axle. Most popular fitment is 7mm Front/15mm Rear combination.
- All kits include appropriate length Wheel Bolts (floating shoulder/ball seat) designed reduce stress on wheel bolts and allow accurate wheel bolt torque.
- OEM Supplier Sourced Wheel bolts are Zinc Coated for added durability and corrosion resistance
- Kits include RSS “Wheel Hanger Tool” for easy installation along with installation insturctions
- Multiple Finish Options: Wheel spacers and bolts are available in Silver/Silver, Black/Black, or Split Finish (Silver Spacers w/Black Bolts)
- Made at RSS in the USA with Premium Grade Materials
- Fitment Guaranteed
Website Link: https://roadsportsupply.com/955-957-...eel-lug-bolts/
RSS ROAD SPORT SUPPLY
2015 Pirelli World Challenge TC Champions
2014 Spanish Rallye Tarmac Champions
2013 Rolex Grand Am GX Champions
mschalke@roadsportsupply.com
www.roadsportsupply.com
Youtube
+ 714-557-2311
Facebook Post
+ 714-557-2311
What size is recommended for a 2009 4S with 235/19 fronts and 305/19 rears. Is 15mm too much for wide body with 305s in the rear?
Good thread!
I just dropped my 997.1 TT on Bilstein B16 Coils. Will be spacing the wheels in a week after the suspension settles. Looking at 8mm / 20mm.
Need to confirm understanding of spacers relative to reduced offset.
In theory, 19x8 wheels w 42mm offset should achieve the same as running 15 mm spacers w stock 19x8 57 offset.
I’m about to order wheels and desires the flush and deep dish look at the same time.
Was thinking ordering 19x11 36mm offset as well with logic of stock 51 - 15mm spacer.
Should work right?
thx.
Should work right?
thx.
Should work right?
thx.
Should work right?
thx.
do you have a photo of your wheels? remember some oem wheels are 8.5 and some are 8. have to see which wheel to know for sure.
15s for sure in the back will be fine with a WB car with 305. the fronts if you have the 8inch front wheel you can do 10-12mm. 7mm is too weak, and 15mm while looking good (i run these), I still tell my friends do do 12mm to be a little on the safer side.
19x8 wheels w 42mm - fronts yes.
for your rears, if your car a NB or WB? if WB then yes 19x11 36mm will work.. if NB 19x11+51 mm MAX
Should work right?
thx.
Should work right?
thx.
Don't forget you can go wider too.
For example, OEM 997.2 GT3 wheels are:
Front: 8.5 x 19" +53 mm offset
Rear: 12 x 19" +63 mm offset
wider wheels = wider tires.
Ohio Performance (04-28-2020)
Spacers
I went with 15mm front and back, my thoughts were I liked the look and moving all four corners out the same should maintain the suspension geomerty. the weird thing is I just put new Michlein Sports on ( tires and wheels balanced as normal) took the car for a run for the first time with the front spacers installed and picked up a wooble at 55-65 mph. My first guess is that I threw a weight ............... as soon as the world comes alive again I will take back down for a rebalance. I could not imagine the spacers would have anything to cause the condition............ thoughts, would like to lower the car but have a driveway that I already have to enter at a angle not to drag the front lip...
