Rear shock PASM wire
https://cimg9.ibsrv.net/gimg/rennlis...ac26f15d0.jpeg Left rear PASM shock. I am installing a DAS Sport roll bar. In order to mount it I need to disconnect the PASM wire feeding into the top of the shock absorber. Can I just unscrew it from the top of the shock? |
looks like I just need to follow the wire to the end of the connector?
Originally Posted by ColoradoMark
(Post 15259745)
Follow the wire to the connector. Don't try to unscrew the wire or twist it. If damaged, it can't be repaired without a new shock.
Thank you all, to be continued.... |
