New to me 997; Terrible Handling
Tire pressures. My car had this floaty feeling and once I took the forums pressure advice (F32/R38 cold) and double checked with a digital gauge against the TPMS it made all of the difference in the world.
Tire pressures are easy to check, start there. I'm thinking the hydraulic filled lower control arm bushings in front are gone given the age of your car. That will definitely give you a sloppy front end. Others could be tie rods, perhaps one half of the front sway bar is loose, maybe strut tops are shot. Either way, if tire pressures do not fix it, get it on a lift with someone who knows suspensions.
There is a lot to check when buying a used P-car... I am sure that we all miss things that might/could show up down the road. I thought I had ~50% rear tread left when I bought my car. That was before I learned about the difference in inboard v outboard wear on the 997. Oops. Sounds like you need to visit another shop/indy and get another opinion on the front end. From your description it sounds like something is amiss. Go for a test drive with a Porsche mechanic and ask them to comment on turn-in, return to center, and free-play.
If the second mechanic says there is an issue then you may want to have a conversation with the PPI provider. They will not be happy to hear from you and you will likely get the standard "this is why I don't like doing PPI" response from the PPI provider.
First of all, spend some money on some struts and springs and an alignment. Assess your tires and tire pressures. Take a look at your steering rods. Replace your engine mounts. This is small money and big improvements in handling/feel. I doubt your steering rack is shot. My 06 is like a new car now after this work.......I didn't need to touch the control arms or bushings or any major dollar work like that. Replacing the engine mounts is cheap and the biggest handling/steering improvement in shifting and lateral stability. The suspension swap overall made the car different and new feeling. Not sure if I went too firm but for the total invested its a new car again. If your car is 11 years old (as mine is) DO IT.
As far as the 987.2 Cayman S comparison.. I also have one of those, and while the steering is crisp and responsive, the 911 should be at least equally so.
It is a 12 year old car that could very well have worn suspension issues or the car could have had a front end collision or front end damage and had bad repairs based on the steering input you described. I have driven many Caymans on the track and I like the steering and feel of the 911 better, especially the 997s. If you turning the wheel and getting no response, there is something wrong in the front end.
Did you not test drive it before purchase? Clean CarFax does not equate no prior damage or wrecks. There are a lot of wrecked and previously damaged cars out there with clean Car Faxes.
As far tires, those are about the cheapest you can get which is never a great idea on a high end performance car. Tires, however, won't cause what your describing at normal freeway and public street speeds.
I’ve had those Hankook tires on a 996 C4S twice and both times they felt very sloppy for the first 200-300 miles. They started to sharpen up after that but you could feel the sidewalk compress on quick transitions and then spring back, which felt like an over correction. After about 1000 miles and enough heat cycles through the tire, that small issue faded away and the tires were pretty good.
With that said, it sounds like you’ve got something else going on with the suspension, in addition to the fresh tires. Get it looked at, quick.
997s are outstanding handling and highly communicative cars vs. virtually anything out there. Sounds like something is wrong. Hopefully it is a relatively straightforward fix. Good luck.
I appreciate everyone's input. I had a shop take a look at the car and the driver's side wheel has play in it--they suggested the tie rods needed to be replaced, so I'm guessing that's the culprit.
Silly question but before you spend a penny....
Have you driven another for comparison?
Has someone else, whether another owner with a similar car or dealer or qualified shop who is actually really familiar with these cars driven yours?
