EB Works fixed Type 3 wing vs OEM Turbo wing
I know wings have been discussed, but I want more specific info on this wing. I also see it by NR Automobile Accessories. It looks to me alot like the Turbo wing. I wonder if anyone has one. The picture is one of these Type 3 fixed wings. I like it.
wings
wings
You'll then need a Durametric or similar to disable the active aero of the stock decklid as that wing won't look good or work right when the decklid deploys.
Personally, I think the Turbo wing with the active aero, where it goes up and down, is pretty cool, but for a fixed wing, that is a good looking one that looks similar to the turbo wing in its resting position.
Thanks, I was wondering about that. I am having trouble getting more detailed info from the website. It just says coupe and cab fitment, but I thing it is only one height used for both. Also says direct bolt on to existing holes, which I like the sounds of.
One thing I notice is that the spoiler looks like it obscures the 3rd brake light below the rear window, but does not look like it has provisions for a light in the spoiler. Third brake lights help to prevent rear end collisions, or if you're in an inspection state, might be a problem if obscured when viewed from the rear of the car. The Turbo wing moves the 3rd brake light to the rear wing. The TT wiring harness has provisions for both the hydraulic pump that does the active aero and for the 3rd brake light in the spoiler. If you go with this wing, you might need to looking into adding a red LED light strip into that wing before it goes to paint and then buy the TT wiring harness to get a wire back there to hook up to it (might need a resistor too if going with LEDs to not get an error).
Maybe I better leave it stock! I'm not good with all that mod stuff. I don't have the patience for it. I have been checking the want ads and Ebay for a used turbo wing, but no luck yet.
PM your email address and i'll send you instructions on how to disable the wing error for a 997.
We have had several people do this retrofit on non- turbo cars. Looks nice.
We have a device to prevent the warning called a MicroModule. Let me know if you want to try one.
Here ya go: https://www.ebay.com/itm/PORSCHE-TUR...cAAOSwXEdaZWAf
