TPC Racing modified shocks
It's been a while since I've made modifications to my 2011 Carrera 977.2 GTS... the car now has ~45,000 miles and it's my daily driver, gone to many Auto-X events plus raced at a lot of tracks in California.
Now's the time for an upgrade or two. I'm very interested in buying adjustable roll bars but found that the GTS w/PDK (special widebody) is difficult to source a rear adjustable bar that doesn't use / need a mounting adapter - except for TPC Racing who makes one that will directly install without the use of an adapter - YES!!
And like I said it's been awhile since I've made an upgrade so I'm thinking that along with the adjustable roll bars, and their necessary / required suspension links, I would also change / upgrade my aging stock shocks. TPC Racing, as it turns out, has a kit (977 Stage 3 Plus Suspension package) which contains everything to satisfy my NEED for more speed. The package includes what they're calling a "modification of the off-the-shelf Bilstien Damptronic Coilovers". These are able to work with my PASM unit so that's a real plus since I'm also using a DSC Sport V1 Control box .
Question ?? has anyone on the forum had any experience with these modified shocks? Or is willing to express an opinion?
DSC Sport also offers great shocks, the Tractive DDA damper, which uses both my PASM and their V1 Control Box but the cost is quite high.
Tractive is excellent choice but extremely expensive ($7k correctly me if I am wrong). If you want to keep PASM with DSC (very smart in my opinion for mixed street and track use) your choices also are: stock GT3 PASM coilovers for about $1-1.2 (I might be selling mine so you could reach out) or Bilstein coilovers for $2-2.4
Kisik, I'm intrigued with your OEM / stock GT3 PASM coilover idea - this is not something that I had considered... But fitment is a concern and also if they're used then reliability is important. Tell all ;>) about your desire to replace your set. Thanks.
I was looking at this thread the other day that may be useful to you...
https://rennlist.com/forums/997-foru...l#post12668451
Mike
Mike
Mike
Yes, that thread is perfect tool for GT3 PASM conversion. Many thanks to Tom at TPC who was always open to share. All you need is set of adapters/spring hats ( I still have them from Tom), cable extensions (sourced from Bilstein # B4-XA1-Z004A00 for $22), and just sleeves (I am sure Tom still have some).
PASM shocks are very robust and don't require frequent service like JRZ and perfect for dual purpose track/street cars.
Kisik - I'm wanting to move forward with using the GT3 coilovers (yours if avail) plus the hats & sleeves and the TPC sway bars etc. from TPC Racing (I'm already using the DSC Control box). But I'm having a hard time sourcing the necessary PASM extension cables....
It is very neat(and advantageous to the car owners) that the suspension components on all 997-series cars are modular and mostly interchangeable; from the Carrera, to GT3, to RS 4.0, to GT3 Cup. I am very fortunate to work at a race car shop to have discovered first hand the interchangeability of the suspension parts over the production years of the 997. The handling performance of each particular 997 model(Carrera/C4/Turbo/GT3/GT2/RS/4.0) from the factory is regulated by the PASM controller commands, the shocks & springs config, top mounts, the sway bars, LCA's and front uprights. DSC Sport controller being fully active and programmable to personal preference by the user is the ultimate equalizer across all the 997 models. With the shocks, springs, top mounts, and uprights being modular and mostly interchangeable, the 997 platform is a suspension tuner's delight. For example, by using factory GTx shocks with either factory GTx springs or aftermarket linear-rate springs(such as from Eibach or Swift) and with some aftermarket support for sway bars, front & rear top mount kits, and sleeve, a 997 owner can customize the suspension to GT3 RS 4.0 level and beyond! Here at TPC Racing we developed and offer sway bars, toe links, top mount kits, and other hardware to fuel this market from street to track to competition. The 997 platform is a legit world class GT racing platform with stellar racing results. We love modding these cars and supporting the market with our race winning knowledge.
More info on interchangeability in this thread, in post #12-
https://rennlist.com/forums/997-foru...amptonics.html
Here's a thread by a 997.1 GT3 owner converted to RS 4.0 suspension(which the factory RS 4.0 coilovers can easily be installed on any Carrera with my adapter sleeves)-
https://rennlist.com/forums/997-gt2-...pension-4.html
Tom, looking forward to acquiring all necessary parts (incl adj front & rear GTS sway bars) to facilitate the proper use of GT3 shocks/coilovers on my 997.2 GTS cabrio from TPC Racing. At this time, I'm in touch with Kisik regarding his used GT3 kit and depending on availabilities I'll be filling out the equipment order with your companies' stuff. BTW - I'm already happily running a DSC Control box and wonder if I'll need to have it re-mapped?
