Upgrade to Multifunction Steering Wheel 997.1
Old 05-30-2018, 03:13 PM
CrossT
CrossT's Avatar
Default Upgrade to Multifunction Steering Wheel 997.1
Probably addressed somewhere here in this forum, but I didn’t find. I have a 997.1 without a multifunction steering wheel and was wondering if a multifunction wheel can be installed ?
thanks
todd
07 c2s cab
Summerjack (02-27-2023)
Old 05-30-2018, 03:58 PM
ekam
ekam's Avatar
You'll need to visit the dealer in order to enable the MF buttons.
Old 05-31-2018, 08:04 AM
Petza914
Petza914's Avatar
Received 6,166 Likes on 3,930 Posts
+1. Did it on mine. PO had installed it but it didn't work. Had the dealer enable it during the PPI once I knew I'd be buying the car.
Old 05-31-2018, 10:59 AM
CrossT
CrossT's Avatar
This will be a nice little easy project! Finding one will be the challenge. If Stone grey, I can use my airbag if missing. If black I’ll need an airbag too. Probably can paint my airbag.
todd
07 c2s cab slate grey
Old 05-31-2018, 11:28 AM
CrossT
CrossT's Avatar
Well, found one on eBay but the airbag looks to be a different shape. Mine is round vs triangular.
So, I will just need to locate one with its airbag.
todd
07 C2S cab
Old 05-31-2018, 02:50 PM
sf_c63
sf_c63's Avatar
I have a multi-function triangle airbag steering wheel I would be willing to trade for a round-airbag steering wheel:
Not sure if that's what you're asking?
Old 06-01-2018, 12:02 PM
CrossT
CrossT's Avatar
sf-63: Yes, that would be what I’m looking for. Maybe would paint it if it’s black. I sent a pm to you on it.
Best regards
todd
07 C2S cab
Old 06-01-2018, 01:50 PM
Frank996
Frank996's Avatar
I’m honestly getting more and more confused on the topic.
I asked my OPC in Bern (Switzerland) if my 997.2 C4S could have the multi function steering wheel fitted, and after they had checked the VIN id I was told it was not possible... I have the PCM 3.0 with nav but not the phone module fitted (but does have the BT option) so cannot be because of this.
I have given up tbh...
Old 06-01-2018, 04:40 PM
myw
myw's Avatar
what color are you looking for ? I'm swapping out mine very soon, steering wheel MF + triangle air bag.... sea blue mint mint condition.
todd
07 C2S cab
Old 06-02-2018, 07:42 PM
CrossT
CrossT's Avatar
Thx. I’m primarily looking either for Stone Grey or, secondarily, black. Otherwise, I will need to re paint, which is a possibility with a dark color. I may have the console and door card plastic re dyed so, the wheel could be done then too.
todd
07 C2S cab slate grey
Old 11-10-2018, 09:02 PM
CrossT
CrossT's Avatar
Picked up a 997.1 MF wheel and have installed it. As expected, the buttons don’t work. So, I was wondering if enabling them is dealer-only and what it’s likely to cost.
Todd
07 997 C2S cab
09 957 GTS
08 BMW K1200GT
Old 11-10-2018, 09:08 PM
Petza914
Petza914's Avatar
Todd
07 997 C2S cab
09 957 GTS
08 BMW K1200GT
You will need at least a Durametric Pro that's capable of module coding or possibly even the dealer's PIWIS system. I had mine done at the dealer during my PPI. They had never done it before and it took a few tries, but we finally got it working and it has been perfect ever since (2012).
Old 11-11-2018, 11:14 AM
doclouie
doclouie's Avatar
I went through this a couple months ago after getting lots of help on here from some who have already posted, Petra. Yes a dealer trip is in order to make it work properly. Dealing with the dealer was more painful than going to the dentist for me. They just do not like to do this kind of stuff on these cars or at least none of the three dealers I contacted. I contacted an Indy that was very helpful and even though he had a jail broken PIWIS he said sometimes he can’t get it to work because of firmware issues. Module firmware, car brain firmware etc. sometimes they just conflict and older or newer firmware needs installed to make it work. Only a dealer has access to that. Best of luck. I love my multifunction steering wheel.
Old 11-12-2018, 02:06 PM
shyamvenky
shyamvenky's Avatar
I went to my Indy to get the "activation" done. Took him 30 min or so. Cheaper this way than to buy a PIWIS equivalent.
I told him to enable all the functions, so that the phone would also work with my aftermarket HU.
A subset of the buttons worked with the PCM 2.1, but then I wanted aftermarket anyways.
With the aftermarket HU, all the buttons work (you need the right steering wheel controls adapter).
Old 01-11-2019, 07:36 PM
CrossT
CrossT's Avatar
Took my car to a dealer and they say I need to have a different controller, harness, etc. So, they couldn’t make it work.
Bummer!
Haven’t quite given up yet, but I’m close...
todd
07 C2S cab
09 957 GTS
Quick Reply: Upgrade to Multifunction Steering Wheel 997.1
