Yes it will. A picture of your current and the 991 steering wheel you are looking to fit will help. The 991.2 steering wheel will need a new airbag as well. If you want the buttons and lights to work (with the 991.2 wheel)you will need an additional module.
That wheel will be a straight swap. Your basically just adding a wheel with multifunction. You will need to make a trip to the dealer to enable the multifunction buttons through PIWIS. Nothing else required.
If I understand correctly, this MacanS wheel will fit both a .1 and .2 but requires the .2 airbag in both instances? Also, none of the functions on the wheel do not work?
I have a .2 so I could then reuse the airbag?
Looks like a great improvement. Any other options for OEM wheels that are a simple swap, albeit for a certified tech to change for me? I would really like to get a thicker and more attractive steering wheel in my car. Thanks!
